What is the difference between these two clear signals?
- 1 month ago
All documented:
https://docs.altera.com/r/docs/683522/25.1.1/fifo-ip-user-guide/fifo-synchronous-clear-and-asynchronous-clear-effect
Thanks, sstrell, for sharing the documentation link.
Hi MartinMaa,
Regarding the image tearing issue, I noticed that you had previously filed a support ticket for a similar problem. May I check is issue has been resolved?
For the differences between synchronous clear and asynchronous clear, you may refer to the documentation link shared by sstrell, at Section 1.7 FIFO Synchronous Clear and Asynchronous Clear Effect.
ZiYingE_Altera
- MartinMaa1 month ago
Hi, ZiYingE
These issues have now been resolved. Thank you.
- ZiYingE_Altera1 month ago
Contributor
Hi MartinMaa,
I'm glad that your issue is resolved. I will proceed with closing this case. We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
ZiYingE_Altera
