14 years agoWhat is the difference..?
Hello , I am starter in VHDL .
Is there any difference between two sources below? They are different i think. first source uses vector signal in the entity body. second source uses vector signal in the architecture body. is ther any difference? for example concurrent process or sequential process and so on.. I want to know what is the difference. thanks! ( the difference of contents between two sources is not important for me. i just want to know the differences in vhdl grammar) (1) LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY tank is PORT( tank : IN std_logic_vector(2 downto 0); alarm : OUT std_logic); END tank; ARCHITECTURE arc of tank is BEGIN WITH tank SELECT alarm <= '0' when "000", '0' when "001", '0' when "010", '1' when "011", '0' when "100", '1' when "101", '1' when "110", '1' when "111", '0' when others; END arc; (2) LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY vector is PORT( a,b,c : IN std_logic; x : OUT std_logic); END vector; ARCHITECTURE arc of vector is SIGNAL input : std_logic_vector(2 downto 0); BEGIN input(2)<=a; input(1)<=b; input(0)<=c; WITH input SELECT x <= '1' WHEN "000",. '0' when "001", '1' when "010", '0' when "011", '1' when "100", '1' when "101", '1' when "110", '0' when "111", END arc;3 Replies
synthesizing both codes U will get same hardware with 3 inputs and one output (of cource with cs1400's suggestion). they are not really different.
In addition to Daixiwen, in (2) :
you forgot the case 'others' in the with...select you forgot ";" to close the with...select there is a point which goes for a trip after the first case of the with...select In conclusion, you can compile (1) but not (2). - Altera_Forum
Both codes will produce the same result. The only difference is that (1) takes a 3-bit vector as input and (2) takes 3 separate bits as inputs and regroups them in a vector.
