PPere22's avatar
PPere22
3 years ago
Warning part number CIE-080-1573-001_ Description_ IC_ FPGA_ CYCLONE IV E
"The UUT is failing on Verify SW step on Flash Test
Doing the measurements, we detected 1.5V_CPU be down
This signal is going directly to the FPGA located as U19
No defect related to solder, spheres and polarity on the BGA located as U19
Measurements of the bad signal with Curve Tracer Instrument shows that the BGA has an electrical defect"
  • Hi Pablo,
    I have response to you through forum email. I will proceed to close this case for now.
    AIman
  • Hi,
    Please clarify below:
    • The devices are fresh unit or you get the repack unit from distributor?
    • Any test that you did that spike the current?
    • Do you have any x-ray image for the bad unit?
    Aiman
    • PPere22's avatar
      PPere22
      Hi Aiman,
      1.- The devices are Fresh, and come from Arrow Distribuitor. contact:
      2.- We do not have current spike in the flash test that could directly affect the BGA
      Being that the problem is detectable from ICT, the BGA was already damaged before reaching the "integration" part.
      3.- Yes, attahing photos, you can see details in the phto 2&3.
      Please let me know the next steps for to give with the root cause.
      Waiting for your response.
      Pablo.
  • Hi,
    I have go through the attachment. However I might missed out some information.
    -How many units are failing? eg: 3/10
    -In the email, you mention the issue is Internal short.
    -I will need to do further checking if the failure unit is too high
    Aiman
