PPere22
3 years agoWarning part number CIE-080-1573-001_ Description_ IC_ FPGA_ CYCLONE IV E
"The UUT is failing on Verify SW step on Flash Test Doing the measurements, we detected 1.5V_CPU be down This signal is going directly to the FPGA located as U19 No defect related to solder, spher...
NurAiman_M_Intel
3 years agoHi,
Please clarify below:
- The devices are fresh unit or you get the repack unit from distributor?
- Any test that you did that spike the current?
- Do you have any x-ray image for the bad unit?
Aiman
PPere22
3 years agoHi Aiman,
1.- The devices are Fresh, and come from Arrow Distribuitor. contact:
2.- We do not have current spike in the flash test that could directly affect the BGA
Being that the problem is detectable from ICT, the BGA was already damaged before reaching the "integration" part.
3.- Yes, attahing photos, you can see details in the phto 2&3.
Please let me know the next steps for to give with the root cause.
Waiting for your response.
Pablo.
