PPere22
3 years agoWarning part number CIE-080-1573-001_ Description_ IC_ FPGA_ CYCLONE IV E
"The UUT is failing on Verify SW step on Flash Test Doing the measurements, we detected 1.5V_CPU be down This signal is going directly to the FPGA located as U19 No defect related to solder, spher...
NurAiman_M_Intel
3 years agoHi,
I have go through the attachment. However I might missed out some information.
-How many units are failing? eg: 3/10
-In the email, you mention the issue is Internal short.
-I will need to do further checking if the failure unit is too high
Aiman
PPere22
3 years agoThe failures of the last 10 weeks are 30/684.
See more details in the FA attached from test engineering team Flex, and let me know how proceed with the analisis of root cause.
Waiting for your comments.
