16 years ago
video clock skew
Hi all
I made a video elaboration system using VIPcore and quartus9.2 web edition.
When I compile my project, sometimes i get correct timing analisys, and sometimes i found a critical warning about a clock skew (for the pixel clock and pixel data).
How can I force quartus2 to route some signals to have the minimum routing and clock delay?
best regards
phate
    --- Quote Start ---
    in the timing report windows there is written
    "from" "to"
    TD_CLK27 TD_CLK27
    I suppose is the same clock
    --- Quote End ---
    do use the classic timing analyzer ? If yes, please list a path and post the result expanded ( so that we can see all ) here. In case you use TimeQuest please post the result
    window of "report path".
    Kind regards
    GPK
    "from" "to"
    TD_CLK27 TD_CLK27
    --- Quote Start ---
    Thakts for the reply.
    Yes, I got this kind of messages
    etc.
    THIS time, I have 21 failed paths. Sometimes I get this error, sometimes no, but is a "random" behavior. I don't know why, but I would like to set up quartus compiler to have the rigth timing and rigth paths inside the fpga.
    Vip are made by altera, so i belive there are some setting i did non set correctly in quartus to have correct timing routing...
    kind regards
    phate.
    --- Quote End ---
    you should check for one path, which clock drives the source and which clock drives the receiving register. Are they identical ?
    Kind regards
    GPK
    --- Quote Start ---
    Not operational: Clock Skew > Data Delay Nios_proc:inst1|alt_vip_cti_0:the_alt_vip_cti_0|alt_vip_cti_0_GN:auto_inst|alt_vip_Vid2IS:my_alt_vip_cti|alt_vip_Vid2IS_resolution_detection:resolution_detection|next_active_line_count[4]
    --- Quote End ---
    etc.
    kind regards
    phate.
    --- Quote Start ---
    Hi all
    best regards
    phate
    --- Quote End ---
    a clock skew is only defined between clocks not between clock and data. Clock skew means that you have a different clock routing delay between e.g. two registers. Did you get any timing violation in the timing analysis report (e.g. Hold time ).
    Kind regards
    GPK
