16 years agovideo clock skew
Hi all I made a video elaboration system using VIPcore and quartus9.2 web edition. When I compile my project, sometimes i get correct timing analisys, and sometimes i found a critical warning ab...
16 years ago --- Quote Start --- Hi all I made a video elaboration system using VIPcore and quartus9.2 web edition. When I compile my project, sometimes i get correct timing analisys, and sometimes i found a critical warning about a clock skew (for the pixel clock and pixel data). How can I force quartus2 to route some signals to have the minimum routing and clock delay? best regards phate --- Quote End --- Hi, a clock skew is only defined between clocks not between clock and data. Clock skew means that you have a different clock routing delay between e.g. two registers. Did you get any timing violation in the timing analysis report (e.g. Hold time ). Kind regards GPK
