16 years agovideo clock skew
Hi all I made a video elaboration system using VIPcore and quartus9.2 web edition. When I compile my project, sometimes i get correct timing analisys, and sometimes i found a critical warning ab...
16 years ago --- Quote Start --- Thakts for the reply. Yes, I got this kind of messages etc. THIS time, I have 21 failed paths. Sometimes I get this error, sometimes no, but is a "random" behavior. I don't know why, but I would like to set up quartus compiler to have the rigth timing and rigth paths inside the fpga. Vip are made by altera, so i belive there are some setting i did non set correctly in quartus to have correct timing routing... kind regards phate. --- Quote End --- Hi, you should check for one path, which clock drives the source and which clock drives the receiving register. Are they identical ? Kind regards GPK
