14 years ago
VHDL problem: inputs and constants
Hi all,
I've a problem in VHDL.
This code runs correctly:
library IEEE;
use IEEE.std_logic_1164.all;
entity CLOCK_SIM is
 generic
  constant FREQ : integer:=10000000;
  constant DUTY : integer:=50
 port
  enable : in STD_LOGIC;
  output : out STD_LOGIC
end CLOCK_SIM;
architecture CLOCK_SIM_ARCH of CLOCK_SIM is
begin
 -- Processo principale
 MainProcess : process
  constant RDUTY : real:=real(DUTY)/100.0;
  constant TCLKH : time:=1 sec*((1.0/real(FREQ))*RDUTY);
  constant TCLKL : time:=1 sec*((1.0/real(FREQ))*(1.0-RDUTY));
 begin
  if enable='1' then
   output<='1';
   wait for TCLKH;
   output<='0';
   wait for TCLKL;
  else
   wait until enable='1';
  end if;
 end process MainProcess;
end CLOCK_SIM_ARCH;
but if I make a constant like an input:
library IEEE;
entity pwm_DC is
 generic
  --constant FREQ : integer:=1000000;
 port
  f      : in integer;
end pwm_DC;
architecture pwm_DC_arch of pwm_DC is
signal FREQ : integer;
begin
 FREQ <= f;
 begin
  if enable='1' then
   output<='1';
   wait for TCLKH;
   output<='0';
   wait for TCLKL;
  else
  end if;
end pwm_DC_arch;
this is the error:
# ** error: (vsim-3601) iteration limit reached at time 7 us.
Can anyone help me?
    Hi TRicky,
    thanks to your help I solved the problem.
    Here's the simple code:
    library IEEE;
    entity pwm_DC is
     port
      f      : in real;
      d      : in real;
    end pwm_DC;
    begin
     -- Processo principale: generazione Duty Cycle
      variable FREQ  : real;
      variable DUTY  : real;
      variable RDUTY : real;
      variable TCLKH : time;
      variable TCLKL : time;
     begin
       FREQ  := f;
       DUTY  := d;
       RDUTY := DUTY/100.0;
       TCLKH := 1 sec*((1.0/FREQ)*RDUTY);
       TCLKL := 1 sec*((1.0/FREQ)*(1.0-RDUTY));
       output<='1';
       wait for TCLKH;
       output<='0';
       wait for TCLKL;
    end pwm_DC_arch;
    change TCLKH and TCLKL to signals or variables, and calculate their value at runtime, rather than at elaboration time. Currently, they use the initial value of FREQ, which will be -2^31.
    Hi Kevin,
    thanks a lot for your help.
    I just don't know how to do this.
    I have to change the 2 constants
    constant FREQ
    constant DUTY
    into two input signals.
    By these 2 signals, I can calculate these 2 values
    TCLKH
    TCLKL
    which I use to generate the output signal, a square wave with a duty cycle that depends on my two input values.
    Can you help me?
    You have two constants (tclkh and tclkl) that will depend on the value of a signal 'freq' which in turn depends on the value of another signal 'f'.
    Fix that up by changing those two constants to signals and give it another go...a calculated constant can't depend on a signal, since a signal is not 'constant'
    Kevin Jennings
