14 years agoVHDL problem: inputs and constants
Hi all, I've a problem in VHDL. This code runs correctly:
library IEEE;
use IEEE.std_logic_1164.all;
entity CLOCK_SIM is
generic
constant FREQ : integer:=10000000;
constant DUTY ...
14 years agoHi Kevin,
thanks a lot for your help. I just don't know how to do this. I have to change the 2 constants constant FREQ constant DUTY into two input signals. By these 2 signals, I can calculate these 2 values TCLKH TCLKL which I use to generate the output signal, a square wave with a duty cycle that depends on my two input values. Can you help me?
