paramProd
Community Manager
54 minutes agoMT25QL128 Not Available in ALTASMI_PARALLEL Configuration Device List_FA
I'm working on a design with Cyclone FPGA(s) in a master/slave (active/passive) configuration, using a Micron MT25QL128 flash device for FPGA configuration storage.
While trying to instantiate the ALTASMI_PARALLEL IP, I noticed that the configuration device list only contains devices such as:
- EPCS16/64/128
- EPCQ16/32/64/128/256/512
I cannot find MT25QL128 in the list.
I have the following questions:
- What is the recommended configuration device selection in ALTASMI_PARALLEL when using a Micron MT25QL128?
- Is selecting EPCQ128 the correct approach since both devices are 128 Mbit?
- Are there any known compatibility issues between ALTASMI_PARALLEL and MT25QL128 regarding Read ID, status register access, sector erase, or page programming?
- When converting a SOF to a JIC file in Quartus, i can see in that list as configuration device for an MT25QL128 flash.
For reference:
- FPGA family: Cyclone IV E
- Flash device: Micron MT25QL128
- Configuration method: Active Serial
- Application: Master/Slave FPGA system with configuration stored in external flash
Any guidance or experience with this setup would be greatly appreciated.
Thanks!
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
