15 years ago
VHDL integers initialization and FPGAs
I've started coding in VHDL just less than a year ago - unexperienced student warning!
My question is about integer initalization. I own an Altera DE1 board and I've also got some experience with Xilinx Spartan 3. With both deviced I've noticed a strange thing about integers. I must initialize an integer to some value at declaration level (i.e. signal int : integer range bla to blabla := 0; ), because otherwise my program may freeze or some other voodoo might appear.
Usually I use integer signals for counters (UART interface for instance).
Have you ever encountered this before ?
I guess I'm configuring/doing something wrong as I know that initialization at declaration level doesn't (or shouldn't?) affect the program after synthesis.
    How did you test it without a testbench? did you use a waveform file?
    --- Quote Start ---
    You should/must not take this asynchronous signal as an input to your state machine. This can cause the described freeze.
    --- Quote End ---
    Yes, it's the most likely explanation. In case, state would show an illegal bit combination, it can be easily detected in simulation or with signal tap.
    The probability of dropping into an illegal state with asynchronous inputs also depends on arbitrary design timing details, it may change with design modifications without a clear relation.
    --- Quote Start ---
    --- Quote End ---
    I see, so what is the best way to prevent this from happening? Synchronize the async. inputs feeded into the FSM ?
    --- Quote Start ---
    --- Quote End ---
    Yes, that's the required method, as already mentioned. In those cases, where a safe timing can't be guaranteed, e.g because the clock input may have glitches, the safe state machine option prevents freezing. See the Quartus software handbook for details.
    I was just aware, that my previous statement about default initialization of integers has been incorrect. As Tricky said, integers are initialized to the leftmost value of the range, also in Quartus synthesis. Thus to or downto definition makes an important difference.
    OK, thanks a lot for clearing this up :D
    I will definitely check out that safe state machine option.
    Now I'll try to capture that glitch in SignalTap somehow... I'm not really familiar with state-based trigger flow so I might as well educate myself about it too.
