VHDL constant type synthesis
The constant type here is two-dimension data array constant which is correct when simulating in Modelsim, but is false when mearsured using oscillograph because I can't reach the inner unit of the constant from the result.
I appreciate any suggestions.Thanks.5 Replies
The constant syntax doesn't say anything about how the constant is actually implemented in your design. It may either mean a constant value that's used at compile time or involve ROM inference, when all prerequisites are met. The value would be accessible somehow in any case. "can't reach the index I want" sounds rather unclear. You should tell, what you are actually doing.
Im guessing that what you have synthesized is a ROM. You need to provide the correct address to the rom to access the internal values.
Like the sentence constant RAM:=("....","...",...), I need to reach any index I want when conditions meet. I realize it logically which is correct when simulating, but it went wrong when debug on board using oscillograph. The problem is I can't reach the index I want , or I can't see it in oscillograph
Post some code so that you make more sense.
I'd suggest to explain your problem a bit more because I didn't understand anything.
