--- Quote Start ---
ya thanks for your quick response
actually i have taken if statements to insert the data into the register.
ex:
if (numofbits = "0011") then
data <= "111";
elsif(numofbits = "0100") then
data <= "1111";
end if;
so on i have to write code for variable numofbits for ex: 3 to 16 bits.
is there any other way of writing the code instead of using so many if and elsif statements.
--- Quote End ---
Just how does numofbits 'vary'? The way you've written the above, implies that it does not vary within a given design since if it did then the assignments to 'data' would not be correct since in one case data is three bits, the other it is four. I doubt that is what you intend, but if by chance it is then the code would be...
signal data: std_logic_vector(numofbits - 1 downto 0);
data <= (others => '1');
But like I said, I doubt that is what you intend. Instead, I'm guessing that numofbits is more variable than that, in which case the following would work...
signal data: std_logic_vector(??? downto 0); -- No idea how wide 'data' is
process
data <= (other => '0');
for i in 0 to (numofbits - 1) loop
data(i) <= '1';
end loop;
Kevin Jennings
