14 years agovhdl coding
hi am new to vhdl programming. I need help in wirting the code for inserting variable data into a register. the length of the register should be based on the number of bits of data am giving to the r...
14 years agoData registers in FPGA are hardware elements that need to be assigned at compile time. There's nothing to avoid. The solution given by K_J is a reasonable answer to the problem. If the maximum number of bits is 16, 16 bits must be hold available, so you need to define
signal data: std_logic_vector(15 downto 0); There's no other way in hardware logic design.
