19 years agoVHDL Code
Hello Guys
I write this code with the max plus II. library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity axelaration_div is
port
in_divider : in integer range 0 to 2097151;
clk : in std_logic;
start : in std_logic;
out_divider : out integer range 0 to 2097151
end;
architecture arc_axelaration_div of axelaration_div is
signal div_num : integer range 0 to 65535 ;
signal cntr_01s : integer range 0 to 2400000;
signal cntr_ax : integer range 0 to 63;
signal flag_reset_div_num : std_logic;
signal flag_cntr_01s : std_logic;
begin
process (start)
begin
if rising_edge(start) then
if flag_reset_div_num ='1' then
div_num <= 5000;
end if;
end if;
end process;
process (clk)
begin
if rising_edge(clk) then
cntr_01s <= cntr_01s + 1;
end if;
end process;
process (clk)
begin
if falling_edge(clk) then
if flag_cntr_01s = '1' then
if cntr_01s = 2399999 then
cntr_01s <= 0;
cntr_ax <= cntr_ax + 1;
end if;
if cntr_ax = 3 then
cntr_ax <= 0;
div_num <= div_num - 1000;
end if;
if div_num = 2000 then
div_num <= in_divider;
end if;
end if;
--else
--out_divider <= div_num;
end if;
end process;
end arc_axelaration_div;
I got an error message error: line 19: file c:\documents: unsupported feature error: unresolved signal is multiply driven What is this mean and how i can fix this Error? Thanks Amirster
There are still many errors. Input ports can't be used to drive signals(the 9th clause from the last, "div_num <= in_divider;" will be a VHDL syntax error).
I feel this code is very confused. I don't know what time sequece or logic are you want to realize. I think this is your homework, and you are a student. You can send me an E-mail. I'd like to study it. - Altera_Forum
You are driving the integer type signals "cntr_01s" and "div_num" from more than one process. The compiler can't determine which one of them that should set the signal value.
Integer is not a "resolved" type and cannot be driven by more than one driver. Solve the problem by doing all assignments inside the same process. Some signal types such as "std_logic" are resolved types. They will be evaluated if there are more than one driver process. Example driving an 'Z' and a '1' will resolve a '1' , driving a '1' and a '0' will resolve in an 'X'. This kind of usage is mostly used for test benches and simulation. Different synthesizers and FPGA architecture handles resolved types differently too. Xilinx for example have FPGAs with tri-state buses internally, Altera doesn't. /BitBuster
