19 years agoVHDL Code
Hello Guys I write this code with the max plus II. library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity axelaration_div is ...
19 years agoThere are still many errors. Input ports can't be used to drive signals(the 9th clause from the last, "div_num <= in_divider;" will be a VHDL syntax error).
I feel this code is very confused. I don't know what time sequece or logic are you want to realize. I think this is your homework, and you are a student. You can send me an E-mail. I'd like to study it.
