VHDL code for a sram
hi I am looking for a VHDL code for a sram with something unusual which is an Upper- and a Lower- Byte control. I do not know how to handle this! i have already written this part of code but it is not finished yet
entity sram is port (clk : in std_logic; ce : in std_logic; oe : in std_logic; we : in std_logic; LB : in std_logic; UB : in std_logic; addr : in std_logic_vector(17 downto 0); data_in : in std_logic_vector(15 downto 0); data_out : out std_logic_vector(15 downto 0)); end sram; architecture syn of sram is type ram_type is array (143 downto 0) of std_logic_vector (15 downto 0); signal RAM: ram_type; signal temp: STD_LOGIC_VECTOR (15 downto 0); begin process (clk) begin if clk'event and clk = '1' then if en = '0' then if oe = '1' and we='1' then report "Mauvaise valeur des signaux" severity warning; elsif we='0' then if UB='1' and LB='0' then temp <= "00000000"&data_in[7]&data_in[6]&data_in[5]&data_in[4]&data_in[3]&data_in[2]&data_in[1]&data_in[0]; data_in <= temp; RAM(conv_integer(addr)) <= data_in; elsif UB='0' and LB='1' then temp <= data_in[15]&data_in[14]&data_in[13]&data_in[12]&data_in[11]&data_in[10]&data_in[9]&data_in[8]&"00000000"; data_in <= temp; RAM(conv_integer(addr)) <= data_in; elsif UB='0' and LB='0' then RAM(conv_integer(addr)) <= data_in; end if; elsif oe='0' then if we='0' then report "Mauvaise valeur des signaux" severity warning; elsif we='1' then if LB='0' and UB='1 ' then ?????????????????????????????? data_out <= RAM(conv_integer(addr)) ; end if; end if; end if; end process; end syn; thnak you5 Replies
i have also another request. I am looking for the VHDL code of the SRAm controller SLS_UP3_SRAM. In fact, the SRAM controller provided by altera in SOPC Builder for the cyclone II development board seems not usable to me because it is made for a stratix development board which sram has a 32 width data bus (there is written when I generate my system : data_to_and_from_the_de1_sram). So i read somewher ethat the sram controller I need is SLS_UP3_SRAM but I do not find it!
Can someone help me pleaase? i had another solution which was to take a _hw.tlc file and to edit a new component with it but I do not know how to do it with SOPC Builder. It seems that it does not work properly when I do it.:mad: - Altera_Forum
Thank you for your help; i have just another question. I am working with a 512 kB SRAM with 144 words x 16 bits. In the array of my ram_type what should I put?
thanks Elea - Altera_Forum
assuming all signals are active low:
you cant do this. You will be driving against data in. But temp is also a signal, so you're messing around with registers all over that you dont want. all you need is:elsif we='0' then if UB='1' and LB='0' then temp <= "ZZZZZZZZ"&data_in(7)&data_in(6)&data_in(5)&data_in(4)&data_in(3)&data_in(2)&data_in(1)&data_in(0); data_in <= temp; RAM(conv_integer(addr)) <= data_in;
also - you dont need to set individual bits to 'z' - you can do whole ranges: data_in <= (others => 'z'); basically - delete the temp signal completly - its confusing you and not doing anything for you. You also should declare data_in as an in, not an inout (otherwise it needs renaming). And if this is internal ram, you cant have inouts anyway - you can only have inouts connected to FPGA pins. Now, I think you can work the rest out.if UB='1' and LB='0' then RAM(conv_integer(addr))(7 downto 0) <= data_in(7 downto 0); elsif UB='0' and LB='1' then RAM(conv_integer(addr))(15 downto 7) <= data_in(15 downto 7); end if; - Altera_Forum
I have fixed those problems, my code looks like that now: library ieee; library work; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use work.all; entity sram2 is port (clk : in std_logic; ce : in std_logic; oe : in std_logic; we : in std_logic; LB : in std_logic; UB : in std_logic; addr : in std_logic_vector(17 downto 0); data_in : inout std_logic_vector(15 downto 0); data_out : out std_logic_vector(15 downto 0) ); end sram2; architecture syn of sram2 is type ram_type is array (262144 downto 0) of std_logic_vector (15 downto 0); signal RAM: ram_type; signal temp: STD_LOGIC_VECTOR (15 downto 0); begin process (clk) begin if clk'event and clk = '1' then if ce='1' then RAM(conv_integer(addr)) <= "ZZZZZZZZZZZZZZZZ"; elsif ce = '0' then if oe = '1' and we='1' then report "Mauvaise valeur des signaux" severity warning; elsif we='0' then if UB='1' and LB='0' then temp <= "ZZZZZZZZ"&data_in(7)&data_in(6)&data_in(5)&data_in(4)&data_in(3)&data_in(2)&data_in(1)&data_in(0); data_in <= temp; RAM(conv_integer(addr)) <= data_in; elsif UB='0' and LB='1' then temp <= data_in(15)&data_in(14)&data_in(13)&data_in(12)&data_in(11)&data_in(10)&data_in(9)&data_in(8)&"ZZZZZZZZ"; data_in <= temp; RAM(conv_integer(addr)) <= data_in; elsif UB='0' and LB='0' then RAM(conv_integer(addr)) <= data_in; end if; elsif oe='0' then if we='0' then report "Mauvaise valeur des signaux" severity warning; elsif we='1'then if UB='1' and LB='0' then RAM(conv_integer(addr))(15)<='Z'; RAM(conv_integer(addr))(14)<='Z'; RAM(conv_integer(addr))(13)<='Z'; RAM(conv_integer(addr))(12)<='Z'; RAM(conv_integer(addr))(11)<='Z'; RAM(conv_integer(addr))(10)<='Z'; RAM(conv_integer(addr))(9) <='Z'; RAM(conv_integer(addr))(8) <='Z'; data_out <= RAM(conv_integer(addr)) ; elsif UB='0' and LB='1' then RAM(conv_integer(addr))(7)<='Z'; RAM(conv_integer(addr))(6)<='Z'; RAM(conv_integer(addr))(5)<='Z'; RAM(conv_integer(addr))(4)<='Z'; RAM(conv_integer(addr))(3)<='Z'; RAM(conv_integer(addr))(2)<='Z'; RAM(conv_integer(addr))(1)<='Z'; RAM(conv_integer(addr))(0)<='Z'; data_out <= RAM(conv_integer(addr)) ; else data_out <= RAM(conv_integer(addr)) ; end if; end if; end if; end if; end if; end process; end syn; My question is that ModelSim does not recognized 'Z' which is high-Z. How can I do? thanks for your answer - Altera_Forum
I see many problems with this code:
1. you're missing a few end if; lines 2. data_in <= temp; is not possible, because data_in is an input 3. you cant use [] in VHDL I dont know what you're trying to do with the temp signal. You dont need it. Fix these problems first, but you're nearly there.
