17 years agoVHDL code for a sram
hi I am looking for a VHDL code for a sram with something unusual which is an Upper- and a Lower- Byte control. I do not know how to handle this! i have already written this part of code but it is no...
17 years agoassuming all signals are active low:
elsif we='0' then
if UB='1' and LB='0' then
temp <= "ZZZZZZZZ"&data_in(7)&data_in(6)&data_in(5)&data_in(4)&data_in(3)&data_in(2)&data_in(1)&data_in(0);
data_in <= temp;
RAM(conv_integer(addr)) <= data_in;
you cant do this. You will be driving against data in. But temp is also a signal, so you're messing around with registers all over that you dont want. all you need is:
RAM(conv_integer(addr))(7 downto 0) <= data_in(7 downto 0);
elsif UB='0' and LB='1' then
RAM(conv_integer(addr))(15 downto 7) <= data_in(15 downto 7);
end if;
also - you dont need to set individual bits to 'z' - you can do whole ranges: data_in <= (others => 'z'); basically - delete the temp signal completly - its confusing you and not doing anything for you. You also should declare data_in as an in, not an inout (otherwise it needs renaming). And if this is internal ram, you cant have inouts anyway - you can only have inouts connected to FPGA pins. Now, I think you can work the rest out.
