19 years ago
VHDL - bit set, or net set?!?
Hello!
Maybe I am in the wrong forum, but I have a big problem which I am not able to resolve myself. . . . Perhaps, somone can help.
I use a Stratix EP1S10 device for my design. It is on a NIOS Dev Kit, but I use it without NIOS. I have written a design in VHDL and all works pretty fine (for my first big project). Now, my design needs about 82% of the logic elements of the FPGA.
I use Quartus II 7.1 for developing my design.
Now, I reached a point where I need some help because I have an error that I can't solve by myself. First look at this code please:
if(fb_pt_read_byte_counter = 0) then
	if(processing_state_register = b"000") then --0
		temp_type <= (others => '0'); -- reset temp_type & temp_level
		temp_level <= 127;
		processing_state_register <= b"001"; --1
	end if;
	if(processing_state_register = b"001") then --1
		temp_type(0) <= fb(fb_pt_read)(7); -- get msb out of first dataset-byte
		temp_level <= conv_integer(fb(fb_pt_read)(6 downto 0)); -- get level out of first dataset-byte
		processing_state_register <= b"010"; --2
	end if;
	if(processing_state_register = b"010") then --2
		processing_state_register <= b"011"; --3
	end if;
	elsif(fb_pt_read_byte_counter = 1) then
		if(processing_state_register = b"011") then --3
			temp_type(4 downto 1) <= fb(fb_pt_read)(3 downto 0); -- get next type-bits out of second dataset-byte
			processing_state_register <= b"100"; --4
		end if;
		if(processing_state_register = b"100") then --4
			case temp_type is
			when "01001" => processing_state_register <= b"000";
			when "01010" => processing_state_register <= b"000";
			when others => 	processing_state_register <= b"101"; --5
			end case;
		end if;
		elsif(fb_pt_read_byte_counter = 2) then
			if(processing_state_register = b"101") then --5
				case temp_type is
				when "00011" => counter1 <= counter1 + 1;
				when "00110" => counter2 <= counter2 + 1;
				when "00111" => counter3 <= counter3 + 1;
				when "01000" => counter4 <= counter4 + 1;
				when "01011" => counter5 <= counter5 + 1;
				when "01101" => counter6 <= counter6 + 1;
				when "01110" => counter7 <= counter7 + 1;
				when others => nop_bit <= not nop_bit;
				end case;
				processing_state_register <= b"110"; --6
			end if;
			if(processing_state_register = b"110") then --6
				case temp_type is
				when "00011" => if(level1 > temp_level) then
							level1 <= temp_level;
						end if;
				when "00110" => if(level2 > temp_level) then
							level2 <= temp_level;
						end if;
				when "00111" => if(level3 > temp_level) then
							level3 <= temp_level;
						end if;
				when "01000" => if(level4 > temp_level) then
							level4 <= temp_level;
						end if;
				when "01011" => if(level5 > temp_level) then
							level5 <= temp_level;
						end if;
				when "01101" => if(level6 > temp_level) then
							level6 <= temp_level;
						end if;
				when "01110" => if(level7 > temp_level) then
							level7 <= temp_level;
						end if;
				end case;
				processing_state_register <= b"000"; --0
			end if;
		end if;
What I posted here is a part of my UART_interface-entity. In this entity I prepare my datasets for to be send via the UART-line. Each dataset consits of three byte. In these three bytes I have packed a signal-level-part, a type-part and a time-part.
Before I send theses datasets I want to count how many datasets of seven different types I send via the serial line and I make a minimum determination for each datatype.
Firstly, I build up my temp-variables, in order to get the actual type and level. The temp_type variable has to be build up in two steps because one bit is packed in the first byte of my dataset and the next 4 bits are packed in the second byte of the pulse dataset.
I set the temp_type value in these two lines:
'fb' is my fifo-buffer in which I store the datasets byte-wise. fb_pt_read is the read-pointer which points to the byte in the buffer which is to be send next.
The counter 'fb_pt_read_byte_counter' stores the information about the actual byte of my three-byte-dataset.
If fb_pt_read_byte_counter = 0, I get the level information out of dataset-byte 0 and the first bit for my temp_type signal.
If fb_pt_read_byte_counter = 1, I get the remaining bits for my temp_type signal out of dataset-byte 1.
If fb_pt_read_byte_counter = 1, I analyze the values stored in temp_type and temp_level in order to increment the right counter and to update the right level.
I hope you can follow my description up to now . . . . :D
Now, all works fine EXCEPT when the value in temp_type becomes b01001 -> d9. Then, very often, the counter4 is incremented although it should only increment on the temp_type b01000 -> d8. All other counters work as expected. I do not know what can be wrong.
Is it perhaps because the lsb in temp_value gets lost somehow, so that b01001 changes to b01000? As far as I can say, all timings work fine, because I do not get any warnings from Quartus II.
In the simulation I do not get any errors either. But something has to be wrong, because all works fine except for this one error.
I know, it is very hard for you to help me in this case, bacause you only see this little part of my design, but maybe someone of you sees a fundamental error in this code. I am very desperate, because I don't know what to do anymore about this error.
Greets
Maik
    Hello plasma16!
    Thanks for your answer.
    You are right, it is very hard for me to write "real" vhdl code, as I come from normal software languages. I have to work on that in the future.
    For now, I solved the problem by checking the counter4-value-changes if they were valid changes or not. If they were invalid, i undo the change by overwriting the new value with a backup of the old value. I know, that this is an unpleasent solution, but I do not know how to help myself anymore.
    That this "solution" does work shows me, that each time a binary 01001 should be in the temp_type signal it is actually a binary 01000. I don't have a clue why, because the only place I touch the temp_type signal is shown in the code example. I NEVER erase the LSB of temp_value . . . . and it is never erased in the case of e.g. binary 00111, 01011 or 01101 as the counters who increment on these temp_type values always behave as expected. They NEVER count wrong.
    Okay, thanks anyway for trying to help me!
    In my next project I hope my vhdl style will improve a little bit ;) .
    Greets,
    Maik
    Maik,
    I can't give you a definitive answer as I don't fully understand your code, but what I can see is that you have multiple nested if-statements in a huge process block, with interchanged levels for fb_pt_read_byte_counter and processing_state_register.
    Here are some tips:
    1. Break down the code into multiple smaller process blocks.
    2. Use a FSM.
    3. Remove as much as possible nested if-statement.
    Keep in mind that VHDL is a language to describe parallel hardware.
    Try not to think of it as sequential code.
