19 years agoVHDL - bit set, or net set?!?
Hello! Maybe I am in the wrong forum, but I have a big problem which I am not able to resolve myself. . . . Perhaps, somone can help. I use a Stratix EP1S10 device for my design. It is on ...
19 years agoHello plasma16!
Thanks for your answer. You are right, it is very hard for me to write "real" vhdl code, as I come from normal software languages. I have to work on that in the future. For now, I solved the problem by checking the counter4-value-changes if they were valid changes or not. If they were invalid, i undo the change by overwriting the new value with a backup of the old value. I know, that this is an unpleasent solution, but I do not know how to help myself anymore. That this "solution" does work shows me, that each time a binary 01001 should be in the temp_type signal it is actually a binary 01000. I don't have a clue why, because the only place I touch the temp_type signal is shown in the code example. I NEVER erase the LSB of temp_value . . . . and it is never erased in the case of e.g. binary 00111, 01011 or 01101 as the counters who increment on these temp_type values always behave as expected. They NEVER count wrong. Okay, thanks anyway for trying to help me! In my next project I hope my vhdl style will improve a little bit ;) . Greets, Maik
