15 years ago
Verilog Error I don't understand
I described this carry select adder ( 2 bits );
module addercs(inu,ind,sum,cy);
input [1:0] inu,ind;
output [2:0] sum,cy;
reg [2:0] sum;
reg [2:0] cy;
always@(inu or ind)
begin:sumator
cy[0]=0;
sum[0]=inu[0]^ind[0]^cy[0];
cy[1]=(inu[0]&ind[0])|(cy[0]&(inu[0]^ind[0]));
sum[1]=(cy[1]&(inu[1]^ind[1]^1))|(~cy[1]&(inu[1]^ind[1]));
cy[2]=(cy[1]&((inu[1]&ind[1])|(1&(inu[1]^ind[1]))))|(~cy[1]&(inu[1]&ind[1]));
sum[2]=cy[2];
end
endmodule
Here is the test banch for it:
module test_addercs ;
reg [1:0] ku,kd;
wire [2:0] su,c;
addercs# 4 Report(.inu(ku), .ind(kd), .su(sum), .c(cy));
initial begin
ku=0;kd=0;# 40 ;
$monitor("%d = ns" , $time ,,,"inu=%d ind=%d sum=%d cy=%d" ,ku,kd,su,c);
ku=2'b00;kd=2'b00;# 30 ;
ku=2'b00;kd=2'b01;# 30 ;
ku=2'b00;kd=2'b10;# 30 ;
ku=2'b00;kd=2'b11;# 30 ;
ku=2'b01;kd=2'b00;# 30 ;
ku=2'b01;kd=2'b10;# 30 ;
ku=2'b01;kd=2'b11;# 30 ;
ku=2'b10;kd=2'b10;# 30 ;
ku=2'b10;kd=2'b11;# 30 ;
ku=2'b11;kd=2'b11;
end
endmodule
When i simulate i get this error and I don't understand why:
vsim work.test_addercs# vsim work.test_addercs # Loading work.test_addercs# Loading work.addercs# ** Error: (vsim-3006) I:/work/work/vlsida/fisiere sursa/cs/test_AdderCS.v(5): Too many inherited module instance parameters.# Region: /test_addercs# Error loading design
Any ideas? Thank you!
    --- Quote Start ---
    yes. did not worked.
    --- Quote End ---
    removing the# 4 will solve the problem. Maybe you forgot to recompile the file ?
    You also have some naming problems between your model and the testbench.
    reg [1:0] ku,kd;
    wire [2:0] su,c;
    //addercs# 4 Report(.inu(ku), .ind(kd), .su(sum), .c(cy));
    addercs report(.inu(ku), .ind(kd), .sum[/B](sum), .cy(cy));[/B]initial begin
    ku=0;kd=0;# 40 ;
    ku=2'b11;kd=2'b11;
    end
    endmodule
    Kind regards
    GPK
    Do you mean that removing the# 4 from line 5 of the testbench did not resolve the problem?
    Thank you Dan. But this dose not seem to be it.
    Catalin T.
    I think your problem is the "#4" in this line of code:
    When instantiating a module, the '#' is used to specify module parameters. But you haven't defined any parameters (only I/Os) So, simply remove the# 4 and I imagine it will compile.
    Dan S.
