17 years agoVerilog design and testbench
How to differentiate verilog design and testbench syntax? Is it depending on the some symbol like# , $ and so on? is all the syntax with symbol for testbench?
$random is for test bench? thanks3 Replies
Ok, now I understand. Basically Verilog syntax is the same for a DUT and testbench. The main difference that if the DUT should be synthesized is written in RTL style. RTL style contains mostly only synthesizable constructs, and a testbench can contain whatever you want.
Generaly a testbench can be recognized that it doesn't have ports, i.e: module tb (); It has initial block which cannot exist in the DUT. It has a clock generator which cannot be in the RTL style: always # 5 clk = ! clk; And can contain nonsynthesisable tasks as $monitor, $display, $finish etc. - Altera_Forum
Basically, i just want to know the code written(syntax) is for RTL design or testbench. It is because i download the summary of verilog where it contains syntax for testbench and RTL design.
--- Quote Start --- How to differentiate verilog design and testbench syntax? Is it depending on the some symbol like# , $ and so on? is all the syntax with symbol for testbench? $random is for test bench? thanks --- Quote End --- What is the purpose of this? Do you want to perfom a language detection automatically by your software? Verilog: `timescale 1 ns / 1 ns module simple_counter_top( osc_clk, rst, led ); input osc_clk; ... endmodule VHDL: LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY simple_counter IS PORT ( rst : IN STD_LOGIC; osc_clk : IN STD_LOGIC; led : OUT STD_LOGIC_VECTOR(3 DOWNTO 0) ); END simple_counter; ARCHITECTURE bdf_type OF simple_counter IS COMPONENT smp_counter ..... end architecture;
