15 years ago
Verilog code errors???
I have this piece of code which when compiled with Quartus II web free resulting in errors (follow comment //). Please advise how to fix them. Thanks.
1) assign Sclk = SCLKout;
assign CS_1 = (posedge Clk26mhz) ? CS1reg :
; // Error (10170): Verilog HDL syntax error at spi_intf.v(55) near text "posedge"; expecting an operand
assign CS_2 = (posedge Clk26mhz) ? CS2reg :
; //Error (10170): Verilog HDL syntax error at spi_intf.v(55) near text "posedge"; expecting an operand
Declaration: Sclk, Clk26mhz, CS_1, CS_2 as output type; SCLKout, CS1reg, CS2reg as reg type
2) assign# 500 rstb = 1'b0; 1'b1;
// Error (10170): Verilog HDL syntax error at tb_pcm.v(35) near text "1"; expecting "endmodule"
Declaration: rstb as wire
Note: the equivalent VHDL code (no error) is: rstb <= '0', '1' after 500ns;
    Nails is right, you cannot assign an inout type in an process, if did, how to handle the "in" part of the signal?
    I have another error:
    if (Data_Lmt == 0)
    begin
    CS1reg <= 1'b1;
    CS2reg <= 1'b1;
    Databus <= SPIdata_reg; // Error (10137): Verilog HDL Procedural Assignment error at spi_intf.v(161): object "Databus" on left-hand side of assignment must have a variable data type
    BUSY <= 1'b0;
    Comm_RW_state <= SPI_RW_Statmachine_Read_repeat;
    end
    Declaration: databus is inout type of 8bits, SPIdata_reg is type reg of 8bits
    Please advise. Thanks.
    Two comments:
    - As shown, it's no legal Verilog syntax
    - Verilog (as well as VHDL) delay statements are simply ignored in synthesis
    First problem, you are trying to uses assign statements for registers.
    Better to uses:
    CS_1 and CS_2 would have to be defined as registers.
    always @(posedge Clk26mhz)
    begin
    CS_1 <= CS1reg;
    CS_2 <= CS2reg;
    end
    I'm assuming on your# 2, you are trying to do a test bench reset strobe where rstb = 0 for 500 ticks then 1.
    This should be done in an initial block. and rstb defined as a register.
    initial
    begin
    rstb = 1'b0;
    # 500
    rstb = 1'b1;
    end
