12 years agoverilog case statement
hi ,
i am facing a problem in verilog case statement .when i put inputs (00,01,10,11) at inputs 00 and 10 to cntrl1 and cntrl2, it outputs the value from in0. i use Xilinx software and my code is as follows : module multiplexer(out,in0,in1,in2,in3,cntrl1,cntrl2); input in0,in1,in2,in3,cntrl1,cntrl2; output out; reg out; always @(in0 or in1 or in2 or in3 or cntrl1 or cntrl2) case ({cntrl2,cntrl2}) 2'b00 : out = in0; 2'b01 : out = in1; 2'b10 : out = in2; 2'b11 : out = in3; default : $display("Please check control bits"); endcase endmodule2 Replies
--- Quote Start --- hi , i am facing a problem in verilog case statement .when i put inputs (00,01,10,11) at inputs 00 and 10 to cntrl1 and cntrl2, it outputs the value from in0. i use Xilinx software and my code is as follows : module multiplexer(out,in0,in1,in2,in3,cntrl1,cntrl2); input in0,in1,in2,in3,cntrl1,cntrl2; output out; reg out; always @(in0 or in1 or in2 or in3 or cntrl1 or cntrl2) case ({cntrl2,cntrl2}) 2'b00 : out = in0; 2'b01 : out = in1; 2'b10 : out = in2; 2'b11 : out = in3; default : $display("Please check control bits"); endcase endmodule --- Quote End --- did you mean case ({cntrl1,cntrl2}) instead of case ({cntrl2,cntrl2}) - Altera_Forum
--- Quote Start --- did you mean case ({cntrl1,cntrl2}) instead of case ({cntrl2,cntrl2}) --- Quote End --- u r right . thnkx
