14 years agovdhl code for 7segment display
i am writing a vhdl code at the moment, am trying to display no 1234 on a 7 segment display but at different times with delay but most time it shows the output at the same time. can anyone help me with that? thanks
Because you have only instantiated the timer architecture, there is no switch to select which character.
You can only use 1 architecture when you instantiate a component. You need to combine the architectures. - Altera_Forum
library ieee;
use ieee.std_logic_1164.all; entity seq2_tb is end seq2_tb; architecture test of seq2_tb is signal A: std_logic; signal s: bit_vector ; signal B : std_logic; signal C: std_logic; begin instance1: entity work.seq2(Timer) port map (PB=>A, X=>S ,clk =>B , reset=>C); S<="1001111" after 10 sec; S<="0110010" after 15 sec; S<="0000110" after 20 sec; S<="1001100" after 25 sec; S<="0100100" after 30 sec; S<="01100" after 35 sec; end test; Another test bench i wrote. - Altera_Forum
The first architecture is for the timer and the second is for the structure. also i have to enable to just 1 switch to produce the output in sequence.
Two more questions first.
Why have you got 2 architectures for the seq2 entity? You can only use 1 architecture at a time. In the testbench you instantiate the seq entity. But the code you posted shows the Seq2 entity. What is the correct code? Also - please use code tags or post the source files. - Altera_Forum
library ieee;
use ieee.std_logic_1164.all; Entity seq2 is Generic ( CLOCK_FREQ : integer := 49999999 ); port (clk : in std_logic; reset : in std_logic; PB : in std_logic ; Tout : inout integer; x : out bit_vector (6 downto 0) ); end seq2; architecture Timer of seq2 is signal clk1 : STD_LOGIC; signal cntr1s : integer range 0 to CLOCK_FREQ; begin process(clk) is begin if(rising_edge(clk)) then if(cntr1s=CLOCK_FREQ) then cntr1s <= 0; clk1 <= '1'; else cntr1s <= cntr1s +1; clk1 <= '0'; end if; end if; end process; process(clk1, reset) is begin if(reset='1') then Tout <= 0; elsif(rising_edge(clk1)) then Tout <= Tout +1; end if; end process; end Timer; architecture structure of seq2 is constant T1 : integer := 10 ; constant T2 : integer := T1 + 10; constant T3 : integer := T2 + 5; constant T4 : integer := T3 + 20; constant T5 : integer := T4 + 5; constant T6 : integer := T5 + 3; begin process (clk, PB ) begin if (PB = '0' ) then x <= "11001111"; elsif (PB = '1') then case Tout is when T1 => x <= "1001111"; when T2 => x <= "0110010"; when T3 => x <= "0000110"; when T4 => x <= "1001100"; when T5 => x <= "0100100"; when T6 => x <= "01100"; when others => Null; end case; end if; end process; end structure; this is the program i wrote but displays everything at the same time without any delay. - Altera_Forum
how about posting the code you have already and tell us what the problems are?
