14 years agovdhl code for 7segment display
i am writing a vhdl code at the moment, am trying to display no 1234 on a 7 segment display but at different times with delay but most time it shows the output at the same time. can anyone help me w...
14 years agolibrary ieee;
use ieee.std_logic_1164.all; Entity seq2 is Generic ( CLOCK_FREQ : integer := 49999999 ); port (clk : in std_logic; reset : in std_logic; PB : in std_logic ; Tout : inout integer; x : out bit_vector (6 downto 0) ); end seq2; architecture Timer of seq2 is signal clk1 : STD_LOGIC; signal cntr1s : integer range 0 to CLOCK_FREQ; begin process(clk) is begin if(rising_edge(clk)) then if(cntr1s=CLOCK_FREQ) then cntr1s <= 0; clk1 <= '1'; else cntr1s <= cntr1s +1; clk1 <= '0'; end if; end if; end process; process(clk1, reset) is begin if(reset='1') then Tout <= 0; elsif(rising_edge(clk1)) then Tout <= Tout +1; end if; end process; end Timer; architecture structure of seq2 is constant T1 : integer := 10 ; constant T2 : integer := T1 + 10; constant T3 : integer := T2 + 5; constant T4 : integer := T3 + 20; constant T5 : integer := T4 + 5; constant T6 : integer := T5 + 3; begin process (clk, PB ) begin if (PB = '0' ) then x <= "11001111"; elsif (PB = '1') then case Tout is when T1 => x <= "1001111"; when T2 => x <= "0110010"; when T3 => x <= "0000110"; when T4 => x <= "1001100"; when T5 => x <= "0100100"; when T6 => x <= "01100"; when others => Null; end case; end if; end process; end structure; this is the program i wrote but displays everything at the same time without any delay.
