14 years agovdhl code for 7segment display
i am writing a vhdl code at the moment, am trying to display no 1234 on a 7 segment display but at different times with delay but most time it shows the output at the same time. can anyone help me w...
14 years agolibrary ieee;
use ieee.std_logic_1164.all; entity seq2_tb is end seq2_tb; architecture test of seq2_tb is signal A: std_logic; signal s: bit_vector ; signal B : std_logic; signal C: std_logic; begin instance1: entity work.seq2(Timer) port map (PB=>A, X=>S ,clk =>B , reset=>C); S<="1001111" after 10 sec; S<="0110010" after 15 sec; S<="0000110" after 20 sec; S<="1001100" after 25 sec; S<="0100100" after 30 sec; S<="01100" after 35 sec; end test; Another test bench i wrote.
