Fpga_Egr_2025's avatar
Fpga_Egr_2025
1 day ago
UVM Questasim simulation
HI ,
I am trying to simulate a generic ALU in Systemverilog UVM test environment . My add_i is random input signal , but when i open my wave i dont see it toggling , but the display function reports it is being toggled ?
here are my files :
// alu package file //
package alu_pkg;
//----Transaction Class----
class transaction;
//declaring the transaction items
rand bit [3:0] a;
rand bit [3:0] b;
bit [6:0] c;
rand bit add_i;
function void display(string name);
$display("-------------------------");
$display("- %s ",name);
$display("- a = %0d, b = %0d",a,b);
$display("- c = %0d",c);
$display("-- ADD = %b --",add_i);
endfunction
endclass
//-----------Driver Class------------------
class driver;
//used to count the number of transactions
int no_transactions;
//creating virtual interface handle
virtual intf_alu#(.WORD_LENGTH(4)) vif;
//creating mailbox handle
mailbox gen2driv;
//constructor
function new(virtual intf_alu vif,mailbox gen2driv);
//getting the interface
this.vif = vif;
//getting the mailbox handles from environment
this.gen2driv = gen2driv;
endfunction
//Reset task, Reset the Interface signals to default/initial values
task reset;
wait(vif.reset);
$display("[ DRIVER ] ----- Reset Started -----");
vif.a <= 0;
vif.b <= 0;
vif.valid <= 0;
vif.add_i <= 0;
vif.mul_i <= 0;
vif.sub_i <= 0;
vif.div_i <= 0;
vif.and_i <= 0;
vif.or_i <= 0;
vif.xor_i <= 0;
wait(!vif.reset);
$display("[ DRIVER ] ----- Reset Ended -----");
endtask
//drivers the transaction items to interface signals
task main;
forever begin
transaction trans;
gen2driv.get(trans);
@(posedge vif.clk);
vif.valid <= 1;
//vif.add_i <= 1;
vif.a <= trans.a;
vif.b <= trans.b;
@(posedge vif.clk);
vif.valid <= 0;
//vif.add_i <= 0;
trans.c = vif.c;
@(posedge vif.clk);
trans.display("[ Driver ]");
no_transactions++;
end
endtask
endclass
//----Generator Class------------------
class generator;
//declaring transaction class
rand transaction trans;
//repeat count, to specify number of items to generate
int repeat_count;
//mailbox, to generate and send the packet to driver
mailbox gen2driv;
//event, to indicate the end of transaction generation
event ended;
//constructor
function new(mailbox gen2driv);
//getting the mailbox handle from env, in order to share the transaction packet between the generator and driver, the same mailbox is shared between both.
endfunction
//main task, generates(create and randomizes) the repeat_count number of transaction packets and puts into mailbox
task main();
repeat(repeat_count) begin
trans = new();
if( !trans.randomize() ) $fatal("Gen:: trans randomization failed");
trans.display("[ Generator ]");
gen2driv.put(trans);
end
-> ended; //triggering indicatesthe end of generation
endtask
endclass
//----Environment Class------------------
class environment;
//generator and driver instance
generator gen;
driver driv;
//mailbox handle's
mailbox gen2driv;
//virtual interface
//constructor
function new(virtual intf_alu vif);
//get the interface from test
this.vif = vif;
//creating the mailbox (Same handle will be shared across generator and driver)
gen2driv = new();
//creating generator and driver
gen = new(gen2driv);
driv = new(vif,gen2driv);
endfunction
task pre_test();
driv.reset();
endtask
task test();
fork
gen.main();
driv.main();
join_any
endtask
task post_test();
wait(gen.ended.triggered);
wait(gen.repeat_count == driv.no_transactions);
endtask
//run task
task run;
pre_test();
test();
post_test();
$finish;
endtask
endclass
endpackage
1 Reply
  • ShengN_altera's avatar
    ShengN_altera
    In the alu_pkg.sv posted, you may change //vif.add_i <= 1; to vif.add_i <= trans.add_i;       and
    //vif.add_i <= 0; to vif.add_i <= 0; (for clearing purpose this is optional) then you may get below waveform:
    Attached file for your reference.
