USB Blaster driver conflict with other FTDI kit
I am using a USB blaster (Terasic) and on the same system I need to use two Asix Presto programmers that use the same FTDI device and (apparently) drivers. The Presto devices load up and work perfectly, but the (previously working) Blaster shows a yellow icon in Device Manager and Quartus 7.1 can't find it. Without the Prestos, the Blaster is happy. But I need all of them. I have heard that this is connected with the way that Altera configures the drivers, and have heard talk of a patch, but have no details. I would welcome any advice so I can get the devices to coexist. Thanks Malcolm21 Replies
Thanks for confirming the issue. I'm not sure yet if generally occurs with recent Windows versions and newer USB Blaster drivers, or only under particular circumstances.
--- Quote Start --- I found I have to close the terminal program that is using the "other" FTDI device and can't start it again until the USB Blaster is active (e.g. DS-5 debugger is connected or programmer is programming), then both will run fine until Blaster is inactive. Tedious but is works. --- Quote End --- Yes, I believe that has worked for me too. Considering that the USB Blaster reconnects in various situations (e.g. always after reconfiguring the FPGA, starting a different JTAG debug tool) the method is more a last resort than a solution. Still hope there's an actual solution other than switching to USB Blaster 2 or possibly a Cypress based USB Blaster clone. Regards, Frank - Altera_Forum
I am also getting the same issue with Quartus 16.1, Windows 7 x64.
The workaround described by ep1015 and kflynn works, but is a bit tedious. - Altera_Forum
Could anyone solve this issue?
I am facing it too and could not find a solution. - Altera_Forum
I got a USB Blaster II and now no problem. Expensive fix for what should be easily fixable. Maybe it's to allow Altera/Intel to sell more blasters.
USB Blaster 2 is really more expensive. Why do they do that?
Because they can?
Seriously, it's not like the original doesn't work there's just an annoying caveat to its use. There is a FAQ on the FTDI website that mentions something similar and gives a solution but that is for the person implementing the application. But it would be nice if Altera would respond with at least an explanation! I doesn't seem anybody from Altera read is reading this. So get a usb blaster II or be aware of what FTDI device you need to use at the same time as the blaster I. - AGuan
Ten years already... This combination works for me:
The Blaster driver is the one from Quartus II 14.1, which is v2.4.16, released on 4/21/2009.
And the USB Serial Converter driver is: 2.12.28.0, released on 8/16/2017.
Hope it helps.
- NJuser
Has anyone tried to run Signaltap (over the Byte blaster) while being connected to the FTDI device? I am trying to provide a command over the USB Serial COM port (Tera Term), and wish to see the response of the FPGA through Signaltap. But as discussed in this thread, I can either use the Tera Term or the Byte Blaster. I am using the Rev C Byte Blaster (which I think is the latest).
