18 years agoUSB Blaster driver conflict with other FTDI kit
Hi, I am using a USB blaster (Terasic) and on the same system I need to use two Asix Presto programmers that use the same FTDI device and (apparently) drivers. The Presto devices load up and...
NJuser
7 years agoHas anyone tried to run Signaltap (over the Byte blaster) while being connected to the FTDI device? I am trying to provide a command over the USB Serial COM port (Tera Term), and wish to see the response of the FPGA through Signaltap. But as discussed in this thread, I can either use the Tera Term or the Byte Blaster. I am using the Rev C Byte Blaster (which I think is the latest).
