[USB-Blaster] Detected as "USB-Blaster Variant" on SLES12 – Causing Detection Issues
USB\VID_09FB&PID_6010&REV_0142&MI_00 looks suspicious. It's not listed in usbblasterii.inf shipped with recent Quartus versions. You may check which oem.inf file is linked with this device instance and post its content here.
Frank
- Milan_S9 months ago
Ok, the oem192.inf (C:\Windows\INF) file is used insted of the usbblasterii.inf, but the file content is identical.
- FvM9 months ago
usblasterii.inf is copied to oemxxx.inf during install, that's normal operation.
I was under the impression, there could be a different driver *.inf loaded in non-function state which should reflect in device control manager, but apparently it's not the case.
My old Blaster 1 is:
USB\VID_09FB&PID_6001&REV_0400
USB\VID_09FB&PID_6001with driver from: C:\altera_pro\25.1.1\quartus\drivers\usb-blaster\usbblstr.inf
Blaster II is:
USB\VID_09FB&PID_6010&MI_00with driver form: C:\altera_pro\25.1.1\quartus\drivers\usb-blaster-ii\usbblasterii.inf
I do not know why the REV_XXXX is there when the INF file doesnt contain it.
Both blasters are stable in the device manager but both fails with the Quartus and Agilex 5 board. They can load board 1x or 2x,.. but frequently the Blaster II changes to the variant (in the Quartus programmer hardvare list) and do not work more. The old Blaster simlpy diappears from the Quartus programmer hardware list.
