**Hello David,**
Thank you for the detailed report — this is a **very well-known and frustrating issue** that has affected many engineers using the original **USB-Blaster** (Altera/Intel first-generation programmer) alongside other FTDI-based devices.
Let me give you a clear summary of the situation, the root cause, and the realistic options in 2026.
### Root Cause – Summary
The original USB-Blaster uses an **FT2232D** chip (same as many of your other FTDI devices).
Altera/Intel released a **custom driver** (version 2.12.28.0) many years ago that **intentionally conflicts** with the official FTDI drivers to prevent Windows from loading the generic FTDI driver on the USB-Blaster (which would break JTAG functionality).
When Windows Update pushes the **latest official FTDI driver (2.12.36.20 or newer)**:
- It detects all FTDI devices (including your FT2232D, FT4232HL, FT232R products).
- It tries to update **all** of them — including the USB-Blaster.
- The old Altera driver (2.12.28.0) is still installed → **driver conflict** → **BSOD (Blue Screen of Death)**.
This has been reported since ~2018–2019 and is still happening in 2026 because:
- Intel **never updated** the USB-Blaster driver after ~2015.
- FTDI keeps releasing new drivers (security/bug fixes), triggering Windows Update.
### Your Workaround is Correct & Common
Uninstalling the Altera/Intel driver (2.12.28.0) **before** letting Windows Update apply the new FTDI driver is the standard workaround used by thousands of engineers.
After the update finishes:
→ Re-install the old Altera driver (from Quartus installer or standalone package).
→ USB-Blaster works again.
**The bad news**:
Every time FTDI releases a new driver version (and Windows pushes it), the same crash cycle **will repeat**. This is not going away unless you block Windows Update for FTDI drivers permanently (possible but not recommended for security).
### Best Long-Term Solutions in 2026
1. **Switch to USB-Blaster II (recommended)**
- Intel **USB-Blaster II** (part # USB-Blaster II) uses a **different USB chip** (not FTDI) → **no driver conflict** with modern FTDI devices.
- Fully supported in current Quartus Prime (Lite/Pro/Standard).
- Much faster programming speed.
- Price: ~$300–400 (official), or ~$50–100 for good clones (widely available in China/HK).
- Drawback: Official one is expensive; clones work fine for most users but may have reliability issues.
2. **Use a Third-Party Programmer (Best Value)**
- **Terasic USB-Blaster** (clone but high quality) or **JTAG Blaster** from other vendors.
- **Segger J-Link** (with JTAG adapter) — very reliable, no FTDI conflict, supports many FPGAs/CPLDs.
- **Olimex ARM-USB-OCD-H** or **Tigard** (FTDI-based but with newer drivers that play nicer).
3. **Permanent Workaround (Block FTDI Driver Updates)**
- Use **Windows Device Installation Control** or **Group Policy** to block driver updates for specific Hardware IDs.
- Hardware IDs of your USB-Blaster (FT2232D):
- VID_09FB & PID_6001 or PID_6002 (Altera signature)
- Tools like **wushowhide.diagcab** (Microsoft) or third-party tools like **Driver Store Explorer (RAPR)** can hide the FTDI driver update.
- This stops the crash but means you stay on the old FTDI driver forever (security risk).
4. **Other Minor Annoyance Fix (Multiple FTDI Devices)**
- The old USB-Blaster driver is **very aggressive** and sometimes grabs other FTDI devices.
- Solution: After installing Altera driver, go to Device Manager → right-click other FTDI devices → **Update driver** → **Browse my computer** → select the **official FTDI driver folder** → force it back.
- Or use **zadig** tool (libusb driver) for non-critical FTDI devices.
### Final Recommendation (2026 Reality)
- **Short-term**: Keep using your current workaround (uninstall Altera driver → update → reinstall). It will keep working.
- **Long-term**: **Replace the original USB-Blaster** with USB-Blaster II (official or good clone).
This completely eliminates the conflict and gives you a modern, supported programmer.
The original USB-Blaster is 15–20 years old — it's time to retire it.
If you want, I can help you find a reliable USB-Blaster II clone supplier in Hong Kong/China or give you exact steps for blocking driver updates.
Alternatively, you can visit www.aceicc.com and seek their advice; I got a good answer from them last time.
