Feasibility to implement 350MHz LVDS + soft-CDR on Cyclone 10LP
For Cyclone 10LP, is it feasible to implement for LVDS soft-CDR Rx @ 350MHz? Does anyone has achieved this at this data rate (or lower data rate)?
Thank you very much.
Yours sincerely,
Huang Ruiyi
- FvM
Hi Huang,
I implemented soft CDR in Cyclone 10 LP utilizing PLL dynamic phase shift (requires 1 PLL output per RX channel). I'm effectively using SDR sampling of input data stream, the other RX clock edge is used to detect and track data edge. According to design requirements, I didn't go above 250 MHz but 350 MHz should basically work.
Unfortunately I can't share implementation details.
Frank - AqidAyman_Altera
Hi Huang Ruiyi,
I came across an article from Macnica where it shows a credible, logic‑only data‑recovery technique on Cyclone 10 LP that you can adapt.
However, it does not prove 350 MHz feasibility.
This can be helpful as a conceptual starting point for you.
Reference:
Aqid
