USB Blaster conflicts with other FTDI devices result in PC crash
- 7 months ago
Hi David,
as most AI generated answers, above post mixes correct with incorrect information.
I can confirm that the combination of most recent FTDI and USB Blaster drivers works well for me with Windows 10 and 11. At least on my old Windows 10 computer drivers have updated several times without crashes, may be just luck. I had a problem with older drivers that USB Blaster didn't work if an FT232 USB-to-RS232 converter was active. The problem is gone with latest driver and jtagserver versions, but I don't why exactly.
I'd expect reinstalling USB Blaster driver should work for you.
Regards Frank
**Hello David,**
Thank you for the detailed report — this is a **very well-known and frustrating issue** that has affected many engineers using the original **USB-Blaster** (Altera/Intel first-generation programmer) alongside other FTDI-based devices.
Let me give you a clear summary of the situation, the root cause, and the realistic options in 2026.
### Root Cause – Summary
The original USB-Blaster uses an **FT2232D** chip (same as many of your other FTDI devices).
Altera/Intel released a **custom driver** (version 2.12.28.0) many years ago that **intentionally conflicts** with the official FTDI drivers to prevent Windows from loading the generic FTDI driver on the USB-Blaster (which would break JTAG functionality).
When Windows Update pushes the **latest official FTDI driver (2.12.36.20 or newer)**:
- It detects all FTDI devices (including your FT2232D, FT4232HL, FT232R products).
- It tries to update **all** of them — including the USB-Blaster.
- The old Altera driver (2.12.28.0) is still installed → **driver conflict** → **BSOD (Blue Screen of Death)**.
This has been reported since ~2018–2019 and is still happening in 2026 because:
- Intel **never updated** the USB-Blaster driver after ~2015.
- FTDI keeps releasing new drivers (security/bug fixes), triggering Windows Update.
### Your Workaround is Correct & Common
Uninstalling the Altera/Intel driver (2.12.28.0) **before** letting Windows Update apply the new FTDI driver is the standard workaround used by thousands of engineers.
After the update finishes:
→ Re-install the old Altera driver (from Quartus installer or standalone package).
→ USB-Blaster works again.
**The bad news**:
Every time FTDI releases a new driver version (and Windows pushes it), the same crash cycle **will repeat**. This is not going away unless you block Windows Update for FTDI drivers permanently (possible but not recommended for security).
### Best Long-Term Solutions in 2026
1. **Switch to USB-Blaster II (recommended)**
- Intel **USB-Blaster II** (part # USB-Blaster II) uses a **different USB chip** (not FTDI) → **no driver conflict** with modern FTDI devices.
- Fully supported in current Quartus Prime (Lite/Pro/Standard).
- Much faster programming speed.
- Price: ~$300–400 (official), or ~$50–100 for good clones (widely available in China/HK).
- Drawback: Official one is expensive; clones work fine for most users but may have reliability issues.
2. **Use a Third-Party Programmer (Best Value)**
- **Terasic USB-Blaster** (clone but high quality) or **JTAG Blaster** from other vendors.
- **Segger J-Link** (with JTAG adapter) — very reliable, no FTDI conflict, supports many FPGAs/CPLDs.
- **Olimex ARM-USB-OCD-H** or **Tigard** (FTDI-based but with newer drivers that play nicer).
3. **Permanent Workaround (Block FTDI Driver Updates)**
- Use **Windows Device Installation Control** or **Group Policy** to block driver updates for specific Hardware IDs.
- Hardware IDs of your USB-Blaster (FT2232D):
- VID_09FB & PID_6001 or PID_6002 (Altera signature)
- Tools like **wushowhide.diagcab** (Microsoft) or third-party tools like **Driver Store Explorer (RAPR)** can hide the FTDI driver update.
- This stops the crash but means you stay on the old FTDI driver forever (security risk).
4. **Other Minor Annoyance Fix (Multiple FTDI Devices)**
- The old USB-Blaster driver is **very aggressive** and sometimes grabs other FTDI devices.
- Solution: After installing Altera driver, go to Device Manager → right-click other FTDI devices → **Update driver** → **Browse my computer** → select the **official FTDI driver folder** → force it back.
- Or use **zadig** tool (libusb driver) for non-critical FTDI devices.
### Final Recommendation (2026 Reality)
- **Short-term**: Keep using your current workaround (uninstall Altera driver → update → reinstall). It will keep working.
- **Long-term**: **Replace the original USB-Blaster** with USB-Blaster II (official or good clone).
This completely eliminates the conflict and gives you a modern, supported programmer.
The original USB-Blaster is 15–20 years old — it's time to retire it.
If you want, I can help you find a reliable USB-Blaster II clone supplier in Hong Kong/China or give you exact steps for blocking driver updates.
Alternatively, you can visit www.aceicc.com and seek their advice; I got a good answer from them last time.
Hi David,
Regards Frank
- Farabi_Altera7 months ago
Hello David,
Can you try latest driver for USB Blaster as Frank suggested?
regards,
Farabi
- Daft_engie7 months ago
Hi Farabi
As far as I know 2.12.28.0 is the latest version of the Altera USB blaster driver.
Are you suggesting there is a later version?
If so, could you tell me where to find it?- Farabi_Altera6 months ago
Can you snap picture of your USB Blaster programming cable?
regards,
Farabi
Hi Frank
Thanks for the reply. Must admit it took me longer than it should to realise the above was AI, a lot of the info sounded reasonable.
As you say uninstalling the altera driver, applying updates then re-installing altera driver works, and that will do for now. Does require that you know an FTDI update is incoming.
For the HP Prodesk 400 PCs that we were setting up for the product my company sells, the crash results in a blue screen, and several restarts, but then boots. Annoying but fixable.Sounds like your PC is dealing with it more gracefully!
