17 years agoupdate QuartusII top-entity after modify the standard example
Hello,everyone.
I am new to QuartusII series software. recently I follow the tutorial of ERIKA Enterprise about 2cpu design. With a start of standard example in the installation directory,I complete the generation of SOPCBuilder part. and I am confused about the following instruction in the tutorial: go back to quartus ii, and update the symbol. connect back all the various pinsof the standard design, to their respective components. the top entity of the project is a vhd file. From the context it seems like a bdf top entity. How to update the symbol, since I changed the default component name and make some additions in the SOPCBuilder. Looking forward to your reply. Thank you very much!!
--- Quote Start --- "Pin assignments are made acording pin definitions on it" ,so you mean I don't need to assign the pin artificially? --- Quote End --- I said it because you're using "standard" example, and i guess it has pin assign ments acording to its top-level entity. --- Quote Start --- (By the way, I try to create a symbol block of the newly top-entity, and it remains 6% for a loooooooong time, seems like deadend.) --- Quote End --- I didn't understand your question. --- Quote Start --- I mean if I would like to make some links inside the NIOSII soft core, excepting the outside pin. For example, I would like to link PIO with the reset_n of the second cpu to accomplish a multiprocessor system. --- Quote End --- reset_n pin is always outside sopc system same as PIO pins. - Altera_Forum
--- Quote Start --- Usually, entity my_project_name_sopc defined in my_project_name_sopc.v, is instanced in the top-level entity (my_project_name.v). Pin assignments are made acording pin definitions on it. What do you mean with --- Quote End --- "Pin assignments are made acording pin definitions on it" ,so you mean I don't need to assign the pin artificially? (By the way, I try to create a symbol block of the newly top-entity, and it remains 6% for a loooooooong time, seems like deadend.) I mean if I would like to make some links inside the NIOSII soft core, excepting the outside pin. For example, I would like to link PIO with the reset_n of the second cpu to accomplish a multiprocessor system. Looking forward to your reply. Thank you very much!! - Altera_Forum
--- Quote Start --- it is automatically assigned as a new top-entity of the project,right? --- Quote End --- Usually, entity my_project_name_sopc defined in my_project_name_sopc.v, is instanced in the top-level entity (my_project_name.v). Pin assignments are made acording pin definitions on it. What do you mean with --- Quote Start --- If I would like to create some connections between the interconnections, --- Quote End --- - Altera_Forum
--- Quote Start --- After every generation SOPC Builder creates a file called your_sopc_file_name.vhd, search an entity with same name on it. There you will see the new signals and their names. So, in the top-level entity you can correct necessary parts in "portmap" code. --- Quote End --- Thank you for your reply!! I found a file named my_project_name_sopc.v in the directory. and compared with the original my_project_name.v, it seems like generated by sopc builder. it is automatically assigned as a new top-entity of the project,right? If I would like to create some connections between the interconnections,can I just create a partly bdf file of the project and make the connection? I am quite new to this,looking forward to your reply.Thank you very much!!:) - Altera_Forum
