17 years agoupdate QuartusII top-entity after modify the standard example
Hello,everyone. I am new to QuartusII series software. recently I follow the tutorial of ERIKA Enterprise about 2cpu design. With a start of standard example in the installation directory,I co...
17 years ago --- Quote Start --- "Pin assignments are made acording pin definitions on it" ,so you mean I don't need to assign the pin artificially? --- Quote End --- I said it because you're using "standard" example, and i guess it has pin assign ments acording to its top-level entity. --- Quote Start --- (By the way, I try to create a symbol block of the newly top-entity, and it remains 6% for a loooooooong time, seems like deadend.) --- Quote End --- I didn't understand your question. --- Quote Start --- I mean if I would like to make some links inside the NIOSII soft core, excepting the outside pin. For example, I would like to link PIO with the reset_n of the second cpu to accomplish a multiprocessor system. --- Quote End --- reset_n pin is always outside sopc system same as PIO pins.
