17 years agoupdate QuartusII top-entity after modify the standard example
Hello,everyone. I am new to QuartusII series software. recently I follow the tutorial of ERIKA Enterprise about 2cpu design. With a start of standard example in the installation directory,I co...
17 years ago --- Quote Start --- After every generation SOPC Builder creates a file called your_sopc_file_name.vhd, search an entity with same name on it. There you will see the new signals and their names. So, in the top-level entity you can correct necessary parts in "portmap" code. --- Quote End --- Thank you for your reply!! I found a file named my_project_name_sopc.v in the directory. and compared with the original my_project_name.v, it seems like generated by sopc builder. it is automatically assigned as a new top-entity of the project,right? If I would like to create some connections between the interconnections,can I just create a partly bdf file of the project and make the connection? I am quite new to this,looking forward to your reply.Thank you very much!!:)
