15 years ago
Unwanted inference of RAMs
I am working with an SOPC system design that includes a custom UART component. In the VHDL design of this component, I specify a memory using:
type fifo_type is array (0 to NUMWORDS-1) of std_logic_vector(0 to FIFO_WIDTH-1);
signal fifo_sig : fifo_type;
Up until know, it is OK that the tool places this into an M4K RAM block. However, at this point I need to implment this as registers instead of RAM - the RAM is needed for other memories. Within the context of my SOPC design, I have tried both project settings and attributes to try and prevent the RAM from being used. But the system always grabs this and puts into a RAM.
This does not work in my SOPC system:
attribute ramstyle : string;
attribute ramstyle of fifo_sig : signal is "logic";
So in contrast, if I create a small project that consists only of my VHDL, I can use both the attributes and the global quartus settings to prevent a RAM from being used.
WHY is this happening?
Kevin
    Thakns for the feedback. I mentioned above that using this code alone as it's own project, I can get logic or M4K as I prefer. But this logic is part of a component created for SOPC builder. Regardless of what I do to the logic at this level, I compile my desing (build SOPC system first) and get the M4K. This is why I am stumped.
    Apologies, had not posted code before.
    Kevin
    Can you use code tags next time you post code please :)
    I compiled it with and without a reset. I get an M4K (I used a Cyclone 1) with no reset and logic when there is a reset. When I made a reset signal stuck at '0', it also placed an M4K, so I can only assume your reset is set to '0'.
    the code. comments are in italian, sorry. i am working with the design of my colleagues from Italy.
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    USE ieee.std_logic_signed.ALL;
    USE ieee.numeric_std.all;
    entity fifo_sync is
    generic(
    NUMBIT : integer; -- numero di bit dimensione
    FIFO_FULL_PROTECTION : integer; -- margine in scrittura
    FIFO_WIDTH : integer -- profondità dati
    port(
    clk : in std_logic;
    reset : in std_logic;
    data : in std_logic_vector (0 to FIFO_WIDTH-1);
    rdreq : in std_logic;
    wrreq : in std_logic;
    q : out std_logic_vector(0 to FIFO_WIDTH-1);
    empty : out std_logic;
    full : out std_logic;
    flush : in std_logic);
    end fifo_sync;
    architecture Behavioral of fifo_sync is
    -- Impiegati per realizzare una FIFO di dimensione di potenza di 2
    type lut_type is array (integer range 0 to 8) of integer range 0 to 256;
    constant lut_square : lut_type :=(0, 2, 4, 8, 16, 32, 64, 128, 256);
    -- Numero words FIFO
    constant NUMWORDS : integer := lut_square(NUMBIT);
    -- Dati accessibili con controllo FIFO FULL PROTECTION
    constant numwords_ffp : integer := (NUMWORDS - FIFO_FULL_PROTECTION)-1;
    -- Indirizzi per lettura e scrittura
    signal addr_wr : std_logic_vector(0 to NUMBIT-1);
    signal addr_rd : std_logic_vector(0 to NUMBIT-1);
    -- Numero di dati presenti in FIFO
    signal data_count : std_logic_vector(0 to NUMBIT-1);
    -- Segnali FIFO FULL e EMPTY
    signal full_sig : std_logic;
    signal empty_sig : std_logic;
    -- Abilitazione scrittura e lettura
    signal wr_en : std_logic;
    signal rd_en : std_logic;
    -- knw 2/14/11
    begin
    full <= full_sig;
    empty <= empty_sig;
    -- Abilito la scrittura solo se la fifo non è piena
    wr_en <= wrreq and (not full_sig);
    -- Abilito la lettura solo se la fifo non è vuota
    rd_en <= rdreq and (not empty_sig);
    -- Gestione scrittura e lettura FIFO
    PROC_FIFO: process ( clk, reset )
    begin
    if (reset = '1') then
    for x in 0 to (NUMWORDS-1) loop
    fifo_sig(x) <= (others => '0');
    end loop;
    elsif (clk'event and clk = '1')then
    if(wr_en = '1')then
    fifo_sig(TO_INTEGER(unsigned(addr_wr)))<= data;
    end if;
    q <= fifo_sig(TO_INTEGER(unsigned(addr_rd)));
    end if;
    end process PROC_FIFO;
    -- Calcolo degli indirizzi per lettura, scrittura e numero di dati in FIFO
    -- ad un accesso in scrittura incremento il conteggio dei dati presenti "data_count"
    -- e incremento l'indirizzo per scrivere nella prossima locazione, in lettura
    -- decremento il conteggio dei dati e incremento l'indirizzo per leggere la locazione
    -- successiva
    PROC_CNT_DATA: process ( clk, reset )
    begin
    if (reset = '1')then
    data_count <= (others => '0');
    addr_rd <= (others => '0');
    addr_wr <= (others => '0');
    if (flush = '1') then
    elsif ((wr_en = '1') and (rd_en = '1')) then
    data_count <= data_count; -- incremento e decremento -> conteggio invariato
    addr_rd <= addr_rd + 1;
    addr_wr <= addr_wr + 1;
    elsif (rd_en = '1') then
    data_count <= data_count - 1;
    elsif (wr_en = '1') then -- empty
    data_count <= data_count + 1;
    end if;
    end if;
    end process PROC_CNT_DATA;
    -- Gestione dei segnali full e empty
    begin
    full_sig <= '0';
    empty_sig <= '1';
    if(TO_INTEGER(unsigned(data_count)) = 0)then
    empty_sig <= '1';
    full_sig <= '0';
    elsif(TO_INTEGER(unsigned(data_count)) >= numwords_ffp )then
    full_sig <= '1';
    empty_sig <= '0';
    else
    full_sig <= '0';
    empty_sig <= '0';
    end if;
    end if;
    end process;
    end Behavioral;
    Post up your code. Adding an async reset that is tied low might have been removed during synthesis. Could you tie it to a real reset?
    quite confused now. added the async reset and get the same results. M4K.
    I have tried to the global synthesis rules. If my UART is its own project, the global settings work, as do the attribute statements. When the UART is taken as a component within the SOPC, these things no longer work.
    within the VHDL that instantiates the memory, fifo_sig is the correct name.
    here is an exerpt from the fitter report (reformatted) when the RAM is extracted:
    |UART_TOP:UART_TOP_0| --> |fifo_sync:FIFO_SYNC_RX| --> |altsyncram:fifo_sig_rtl_0| --> |altsyncram_iog1:auto_generated| --> M4Ks = 1
    Try sticking an async reset on fifo_sig - that behaviour is not allowed in RAMs so it will have to place registers.
    Apparently, fifo_sig isn't the correct instance name or you're not in the correct hierarchy scope. Did you try to adjust global RAM inference synthesis rules?
