15 years agoUnwanted inference of RAMs
I am working with an SOPC system design that includes a custom UART component. In the VHDL design of this component, I specify a memory using: type fifo_type is array (0 to NUMWORDS-1) of std_l...
15 years agoI have tried to the global synthesis rules. If my UART is its own project, the global settings work, as do the attribute statements. When the UART is taken as a component within the SOPC, these things no longer work.
within the VHDL that instantiates the memory, fifo_sig is the correct name. here is an exerpt from the fitter report (reformatted) when the RAM is extracted: |UART_TOP:UART_TOP_0| --> |fifo_sync:FIFO_SYNC_RX| --> |altsyncram:fifo_sig_rtl_0| --> |altsyncram_iog1:auto_generated| --> M4Ks = 1
