15 years agoUnwanted inference of RAMs
I am working with an SOPC system design that includes a custom UART component. In the VHDL design of this component, I specify a memory using: type fifo_type is array (0 to NUMWORDS-1) of std_l...
15 years agothe code. comments are in italian, sorry. i am working with the design of my colleagues from Italy.
LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_signed.ALL; USE ieee.numeric_std.all; entity fifo_sync is generic( NUMBIT : integer; -- numero di bit dimensione FIFO_FULL_PROTECTION : integer; -- margine in scrittura FIFO_WIDTH : integer -- profondità dati ); port( clk : in std_logic; reset : in std_logic; data : in std_logic_vector (0 to FIFO_WIDTH-1); rdreq : in std_logic; wrreq : in std_logic; q : out std_logic_vector(0 to FIFO_WIDTH-1); empty : out std_logic; full : out std_logic; flush : in std_logic); end fifo_sync; architecture Behavioral of fifo_sync is -- Impiegati per realizzare una FIFO di dimensione di potenza di 2 type lut_type is array (integer range 0 to 8) of integer range 0 to 256; constant lut_square : lut_type :=(0, 2, 4, 8, 16, 32, 64, 128, 256); -- Numero words FIFO constant NUMWORDS : integer := lut_square(NUMBIT); -- Dati accessibili con controllo FIFO FULL PROTECTION constant numwords_ffp : integer := (NUMWORDS - FIFO_FULL_PROTECTION)-1; type fifo_type is array (0 to NUMWORDS-1) of std_logic_vector(0 to FIFO_WIDTH-1); signal fifo_sig : fifo_type; -- Indirizzi per lettura e scrittura signal addr_wr : std_logic_vector(0 to NUMBIT-1); signal addr_rd : std_logic_vector(0 to NUMBIT-1); -- Numero di dati presenti in FIFO signal data_count : std_logic_vector(0 to NUMBIT-1); -- Segnali FIFO FULL e EMPTY signal full_sig : std_logic; signal empty_sig : std_logic; -- Abilitazione scrittura e lettura signal wr_en : std_logic; signal rd_en : std_logic; -- knw 2/14/11 attribute ramstyle : string; attribute ramstyle of fifo_sig : signal is "logic"; begin full <= full_sig; empty <= empty_sig; -- Abilito la scrittura solo se la fifo non è piena wr_en <= wrreq and (not full_sig); -- Abilito la lettura solo se la fifo non è vuota rd_en <= rdreq and (not empty_sig); -- Gestione scrittura e lettura FIFO PROC_FIFO: process ( clk, reset ) begin if (reset = '1') then for x in 0 to (NUMWORDS-1) loop fifo_sig(x) <= (others => '0'); end loop; elsif (clk'event and clk = '1')then if(wr_en = '1')then fifo_sig(TO_INTEGER(unsigned(addr_wr)))<= data; end if; q <= fifo_sig(TO_INTEGER(unsigned(addr_rd))); end if; end process PROC_FIFO; -- Calcolo degli indirizzi per lettura, scrittura e numero di dati in FIFO -- ad un accesso in scrittura incremento il conteggio dei dati presenti "data_count" -- e incremento l'indirizzo per scrivere nella prossima locazione, in lettura -- decremento il conteggio dei dati e incremento l'indirizzo per leggere la locazione -- successiva PROC_CNT_DATA: process ( clk, reset ) begin if (reset = '1')then data_count <= (others => '0'); addr_rd <= (others => '0'); addr_wr <= (others => '0'); elsif (clk'event and clk = '1')then if (flush = '1') then data_count <= (others => '0'); addr_rd <= (others => '0'); addr_wr <= (others => '0'); elsif ((wr_en = '1') and (rd_en = '1')) then data_count <= data_count; -- incremento e decremento -> conteggio invariato addr_rd <= addr_rd + 1; addr_wr <= addr_wr + 1; elsif (rd_en = '1') then data_count <= data_count - 1; addr_rd <= addr_rd + 1; elsif (wr_en = '1') then -- empty data_count <= data_count + 1; addr_wr <= addr_wr + 1; end if; end if; end process PROC_CNT_DATA; -- Gestione dei segnali full e empty process ( clk, reset ) begin if (reset = '1')then full_sig <= '0'; empty_sig <= '1'; elsif (clk'event and clk = '1')then if(TO_INTEGER(unsigned(data_count)) = 0)then empty_sig <= '1'; full_sig <= '0'; elsif(TO_INTEGER(unsigned(data_count)) >= numwords_ffp )then full_sig <= '1'; empty_sig <= '0'; else full_sig <= '0'; empty_sig <= '0'; end if; end if; end process; end Behavioral;
