15 years agoUnwanted inference of RAMs
I am working with an SOPC system design that includes a custom UART component. In the VHDL design of this component, I specify a memory using: type fifo_type is array (0 to NUMWORDS-1) of std_l...
15 years agoCan you use code tags next time you post code please :)
I compiled it with and without a reset. I get an M4K (I used a Cyclone 1) with no reset and logic when there is a reset. When I made a reset signal stuck at '0', it also placed an M4K, so I can only assume your reset is set to '0'.
