--- Quote Start ---
You have 3.3V/800mA generated from 12V. If you really expect this supply to generate 800mA, it will dissipate P = (12V-3.3V) x 0.8 = 6.96W. It'll get way too hot. Use a switch-mode supply if you really expect to use this much power. A similar argument holds for the 5V supply.
--- Quote End ---
I dont need 800ma i dont think the circuit will draw any where near that. im guessing only 100 or so?, i just like the lm1117 range of regulators + have tapes of them so decided to use it.
--- Quote Start ---
I personally prefer to buffer or put series resistances in the path between the JTAG header and the JTAG pins on the FPGA. This provides some ESD protection ... that zap you hear, right before your board stops working.
--- Quote End ---
sounds good, what value resistor are you thinking some thing like a 1k?
--- Quote Start ---
Check your crystal oscillator circuit. It seems a bit simple. I thought they normally had low valued capacitance near them to tune the oscillation.
--- Quote End ---
im not 100% sure on this i was just copying a simular schematic, ill look at the oscillator part data sheet and see if it needs this cap. :)
--- Quote Start ---
nCONFIG needs a pull-up or pull-down. The low-to-high transition on that signal is what resets the FPGA. See this doc for more details:
--- Quote End ---
ah cool i shall add this.
--- Quote Start ---
Where are all your decoupling capacitors? Make sure you have one per power pin for every device.
--- Quote End ---
all my decoupling caps are under the regulators top right of my schematic, i have 1 cap per pin for the 1.5core voltage and 2 caps, i think i just need 2 caps for my io banks as im only using 2 banks and these banks only use 3 pins and 2 of the pins are very close together. so i think i can get away with just 2 decoupling caps?
--- Quote Start ---
Put a series resistor in your DCLK path and on your oscillator output (to control ringing).
--- Quote End ---
will do, what values should i be using?
thanks for all your feed back its VERY useful :) and ill make all your amendments.
