17 years agoUnunderstood error message
I am working on a VHDL project using the Altera DK-N2EVAL-3C25N development kit which is a NIOS II CYCLONE III environment. While proceeding with the "Start Analysis & Elaboration" menu, I have encountered this error message: 'error (10482): vhdl error at audio_project.vhd(40): object "sclk" is used but not declared'. Knowing that i have already declared "SCLK" in the proper place,I am still wondering where the problem is. This is the code portion where this signal is declared:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
use work.audio_config.all;
entity audio_project is
port(
reset: in std_logic;
ADCDAT : in std_logic_vector(7 downto 0);
DACDAT: out std_logic_vector (7 downto 0);
BCLK : in std_logic
end audio_project;
architecture structural of audio_project is
component fsm is
port(
BCLK : in std_logic;
SCLK : inout std_logic;
SDIN: inout std_logic
end component fsm;
component FIFOMXN is
generic( n : Positive := 8;
m : Positive := 48
); --m is fifo depth, n is fifo width
port(reset, WRREQ, RDREQ, BCLK : in Std_logic;
DATAIN : in Std_logic_vector((n-1) downto 0);
DATAOUT : out Std_logic_vector((n-1) downto 0);
FULL, EMPTY : inout Std_logic);
end component FIFOMXN;
begin
C1 : fsm port map (
reset => reset,
BCLK=>BCLK,
SCLK=>SCLK,
SDIN=>SDIN
fifo_recep: FIFOMXN port map( reset, WRREQ, RDREQ, BCLK, ADCDAT, DATAOUT, FULL, EMPTY);
fifo_trans: FIFOMXN port map( reset, WRREQ, RDREQ, BCLK,DATAIN,DACDAT, FULL, EMPTY);
end structural;
1 Reply
Hi alaaayed:
the port or signal SCLK is not declared in your design. The SCLK that you describe from the fsm module is the name of the port internal in the module but is not known in audio_project. To solve the problem, you should add the definition of the SCLK signal.
