14 years agoUnable to assign PLL*out as LVDS IO standard in Cyclone III
Hello All,
I am unable to assign PLL*out pin to LVDS IO standard in Cyclone 3 device. I have already designed the board with this pinning. The board has Cyclone 3 device and is interfaced to TRXAESMM transceiver for high speed link. Device: EP3C120F484C8 Pins: E5 (PLL3_CLKOUTp) -> connected to RX+ (of TRXAESMM spf module) E6 (PLL3_CLKOUTn) -> connected to RX- (of TRXAESMM spf module) Error Message: Editing location assignment is not successfull. Incompatible IO standard or Pin_E5 cannot be assigned to LVDS IO standards Pin_E6 cannot be assigned to LVDS IO standards Please guide me. I am in trouble if i dont get this solved as my boards are already on there way. note that i have successfully done the same kind of assignment in stratixii device. it works just fine. Best Regards, VVP6 Replies
I was able to check the issue in Quartus today. The problem is that the PLLOUT pins are top/bottom pins that don't support true LVDS output standard, only LVDS_E_3R using external resistors.
The problem reveals immediately if you assign the pins in the Pin Planner tool that shows the available I/O standards for each pin. Frank - Altera_Forum
Hello Friends,
Please let me know if u need any info from my side. The board is designed with this pinnig already. Is there any alternative that i can adopt to to make this work. BEST REGARDS, vvp - Altera_Forum
Please let me know whats wrong with my assignment and how i can get rid of this problem.
I see that this problem is seen with PLL*_out pins. However , i have already checked with stratix II device and PLL out pin assigned as LVDS works just fine. - Altera_Forum
Thanks for the response.
B8 is at 2.5V. Only E5 should be LVDS. Please let me know your suggestion. - Altera_Forum
Most likely reason: wrong bank voltage. B8 voltage of 2.5V is required.
