14 years agoUnable to assign PLL*out as LVDS IO standard in Cyclone III
Hello All, I am unable to assign PLL*out pin to LVDS IO standard in Cyclone 3 device. I have already designed the board with this pinning. The board has Cyclone 3 device and is interfaced...
14 years agoI was able to check the issue in Quartus today. The problem is that the PLLOUT pins are top/bottom pins that don't support true LVDS output standard, only LVDS_E_3R using external resistors.
The problem reveals immediately if you assign the pins in the Pin Planner tool that shows the available I/O standards for each pin. Frank
