18 years ago
uart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated with UART: UART_TXD and UART_RXD.
I want to write my code in verilog, rather than running a soft core proccessor and using the NIOS 2 development suit to code c for it.
My question is, how can I negotiate a clockspeed using just these two pins?
I've been over most of the documentation I can find and there is nothing relevant that I can find.
Thanks in advance for any help.
    Hey all, I finally solved my problem today. Using a multimeter, oscillascope, 2 different serial cables and a soldering iron.
    problems:
    a) although the cable i was using, was the right one, it didn't work in my 25 pin rs232 port. The computer lab has 9 pin sockets, so that is fine.
    b) my code had a few bugs. Below is my completed working code, for archive purposes. Thanks for all your help.
    module test(input  CLOCK_50,
    	output  LEDR,
    	output UART_TXD,
    	input  UART_RXD,
    	input  SW
    	wire serial_clk;
    	new_clock pll(.inclk0(CLOCK_50), .c0(serial_clock));
    	reg  waiter = 12'b0000000000000; //counter to reduce clock rate
    	//reg  waiter = 13'b0000000000000; //counter to reduce clock rate
    	reg  state = 4'b0000; //current state. 0 = start bit, 1-8 = data bits, 9 = stop bit, other = ended
    	reg data = 1'b1; //start high = idle state
    	reg clk_new = 0; //changes the state of an led every time a bit is sent
    	reg  origData = 48'h00_4F_4C_4C_45_48; //HELLO in ascii, little endian
    	reg  currData;
    	reg started = 0;
    	assign LEDR = data; //led outputs current data bit
    	assign LEDR = SW; //led outputs status of a switch
    	assign LEDR = clk_new; //led shows when new bit is sent
    	assign UART_TXD = data; //assert the transmit wire to the data bit
    	always @(posedge serial_clock) //every clock tick
    	begin
    		//if (waiter == 27'b111111111111111111111111111) //1/2 times a second
    		if (waiter == 12'b1100_0011_0100) //9600 times a second (aprox)
    		begin
    			waiter <= 12'b000000000000; //reset counter
    			if (started == 0) //have we not started yet?
    			begin
    				if (SW) //start if switch 0 is high
    				begin
    					started <= 1;
    					currData <= origData; //set the current data register to be the original data register
    				end
    			end
    			else //we have started
    			begin
    				clk_new <= !clk_new; //change clock led
    				if (currData == 48'd0 && state == 4'h0) //end of transmit
    				begin
    					data <= 1'b1; //idle bit
    					if (!SW) //if switch 0 is low, then reset to not started
    					begin
    						started <= 1'b0;
    					end
    				end
    				else
    				begin
    					if (state == 4'h0) //start bit
    					begin
    						data <= 1'b0;
    					end
    					else if(state == 4'h9) //stop bit
    					begin
    						data <= 1'b1;
    					end
    					else if(state < 4'h9) //data bits
    					begin
    						data <= currData; //get first bit
    						currData <= currData >> 1; //right shift, so as first bit is the next bit to send
    					end
    					if (state == 4'h9) //update state
    					begin
    						state <= 4'h0;
    					end
    					else
    					begin
    						state <= state + 1'b1;
    					end
    				end //end data left to transmit
    			end //end started == 1
    		end //end if (waiter == ...)
    		else
    		begin
    			waiter <= waiter + 1'b1;  //inc waiter
    		end
    	end //end always @...
    endmodule
    thats 9600 baud, 1 stop bit, no parity to send a 40 bit string
    I come across a coding in verilog for the UART....
    Just tat when i connect to the ALTERA DE-2 board i seem to stuck on the Tx busy OUTPUT...as by the pin assignmnt i assign PIN B_25 but how bout Tx busy for the output...wat shall i assign???...
    this is my coding..
    // RS-232 TX module
    //`define DEBUG // in DEBUG mode, we output one bit per clock cycle (useful for faster simulations)
    module one(clk, TxD_start, TxD_data, TxD, TxD_busy);
    input clk, TxD_start;
    input [7:0] TxD_data;
    output TxD, TxD_busy;
    parameter ClkFrequency = 25000000; // 25MHz
    parameter Baud = 115200;
    parameter RegisterInputData = 1; // in RegisterInputData mode, the input doesn't have to stay valid while the character is been transmitted
    // Baud generator
    parameter BaudGeneratorAccWidth = 16;
    reg [BaudGeneratorAccWidth:0] BaudGeneratorAcc;
    `ifdef DEBUG
    wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = 17'h10000;
    `else
    wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = ((Baud<<(BaudGeneratorAccWidth-4))+(ClkFrequency>>5))/(ClkFrequency>>4);
    `endif
    wire BaudTick = BaudGeneratorAcc[BaudGeneratorAccWidth];
    wire TxD_busy;
    always @(posedge clk) if(TxD_busy) BaudGeneratorAcc <= BaudGeneratorAcc[BaudGeneratorAccWidth-1:0] + BaudGeneratorInc;
    // Transmitter state machine
    reg [3:0] state;
    wire TxD_ready = (state==0);
    assign TxD_busy = ~TxD_ready;
    reg [7:0] TxD_dataReg;
    always @(posedge clk) if(TxD_ready & TxD_start) TxD_dataReg <= TxD_data;
    wire [7:0] TxD_dataD = RegisterInputData ? TxD_dataReg : TxD_data;
    case(state)
    4'b0000: if(TxD_start) state <= 4'b0001;
    4'b0001: if(BaudTick) state <= 4'b0100;
    4'b0100: if(BaudTick) state <= 4'b1000; // start
    4'b1000: if(BaudTick) state <= 4'b1001; // bit 0
    4'b1001: if(BaudTick) state <= 4'b1010; // bit 1
    4'b1010: if(BaudTick) state <= 4'b1011; // bit 2
    4'b1011: if(BaudTick) state <= 4'b1100; // bit 3
    4'b1100: if(BaudTick) state <= 4'b1101; // bit 4
    4'b1101: if(BaudTick) state <= 4'b1110; // bit 5
    4'b1110: if(BaudTick) state <= 4'b1111; // bit 6
    4'b1111: if(BaudTick) state <= 4'b0010; // bit 7
    4'b0010: if(BaudTick) state <= 4'b0011; // stop1
    4'b0011: if(BaudTick) state <= 4'b0000; // stop2
    default: if(BaudTick) state <= 4'b0000;
    endcase
    // Output mux
    reg muxbit;
    always @( * )
    case(state[2:0])
    3'd0: muxbit <= TxD_dataD[0];
    3'd1: muxbit <= TxD_dataD[1];
    3'd2: muxbit <= TxD_dataD[2];
    3'd3: muxbit <= TxD_dataD[3];
    3'd4: muxbit <= TxD_dataD[4];
    3'd5: muxbit <= TxD_dataD[5];
    3'd6: muxbit <= TxD_dataD[6];
    3'd7: muxbit <= TxD_dataD[7];
    endcase
    // Put together the start, data and stop bits
    reg TxD;
    always @(posedge clk) TxD <= (state<4) | (state[3] & muxbit); // register the output to make it glitch free
    endmodule
    I don't exactly understand the question. TxD_busy is nothing to connect at the external UART interface. It's an internal signal to inform the data source when the UART is ready to accept the next character.
    ok then how bout the inputs....must i connect normal switch as inputs from the altera de-2 board
    https://www.alteraforum.com/forum/attachment.php?attachmentid=5225
    i have attached the picture of the pin assignment...im new in the rs232 section soe ur advise on wat input must i put is really valuable...is it the normal switch in altera de-2 which is from SW0 to SW17 ?? and for the Tx busy if its not connected in external wat output shall i assign since Tx will be assign externally to UART pin...pls Advise
