18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
14 years agoI come across a coding in verilog for the UART....
Just tat when i connect to the ALTERA DE-2 board i seem to stuck on the Tx busy OUTPUT...as by the pin assignmnt i assign PIN B_25 but how bout Tx busy for the output...wat shall i assign???... this is my coding.. // RS-232 TX module //`define DEBUG // in DEBUG mode, we output one bit per clock cycle (useful for faster simulations) module one(clk, TxD_start, TxD_data, TxD, TxD_busy); input clk, TxD_start; input [7:0] TxD_data; output TxD, TxD_busy; parameter ClkFrequency = 25000000; // 25MHz parameter Baud = 115200; parameter RegisterInputData = 1; // in RegisterInputData mode, the input doesn't have to stay valid while the character is been transmitted // Baud generator parameter BaudGeneratorAccWidth = 16; reg [BaudGeneratorAccWidth:0] BaudGeneratorAcc; `ifdef DEBUG wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = 17'h10000; `else wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = ((Baud<<(BaudGeneratorAccWidth-4))+(ClkFrequency>>5))/(ClkFrequency>>4); `endif wire BaudTick = BaudGeneratorAcc[BaudGeneratorAccWidth]; wire TxD_busy; always @(posedge clk) if(TxD_busy) BaudGeneratorAcc <= BaudGeneratorAcc[BaudGeneratorAccWidth-1:0] + BaudGeneratorInc; // Transmitter state machine reg [3:0] state; wire TxD_ready = (state==0); assign TxD_busy = ~TxD_ready; reg [7:0] TxD_dataReg; always @(posedge clk) if(TxD_ready & TxD_start) TxD_dataReg <= TxD_data; wire [7:0] TxD_dataD = RegisterInputData ? TxD_dataReg : TxD_data; always @(posedge clk) case(state) 4'b0000: if(TxD_start) state <= 4'b0001; 4'b0001: if(BaudTick) state <= 4'b0100; 4'b0100: if(BaudTick) state <= 4'b1000; // start 4'b1000: if(BaudTick) state <= 4'b1001; // bit 0 4'b1001: if(BaudTick) state <= 4'b1010; // bit 1 4'b1010: if(BaudTick) state <= 4'b1011; // bit 2 4'b1011: if(BaudTick) state <= 4'b1100; // bit 3 4'b1100: if(BaudTick) state <= 4'b1101; // bit 4 4'b1101: if(BaudTick) state <= 4'b1110; // bit 5 4'b1110: if(BaudTick) state <= 4'b1111; // bit 6 4'b1111: if(BaudTick) state <= 4'b0010; // bit 7 4'b0010: if(BaudTick) state <= 4'b0011; // stop1 4'b0011: if(BaudTick) state <= 4'b0000; // stop2 default: if(BaudTick) state <= 4'b0000; endcase // Output mux reg muxbit; always @( * ) case(state[2:0]) 3'd0: muxbit <= TxD_dataD[0]; 3'd1: muxbit <= TxD_dataD[1]; 3'd2: muxbit <= TxD_dataD[2]; 3'd3: muxbit <= TxD_dataD[3]; 3'd4: muxbit <= TxD_dataD[4]; 3'd5: muxbit <= TxD_dataD[5]; 3'd6: muxbit <= TxD_dataD[6]; 3'd7: muxbit <= TxD_dataD[7]; endcase // Put together the start, data and stop bits reg TxD; always @(posedge clk) TxD <= (state<4) | (state[3] & muxbit); // register the output to make it glitch free endmodule
