18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
18 years agoHey all, I finally solved my problem today. Using a multimeter, oscillascope, 2 different serial cables and a soldering iron.
problems: a) although the cable i was using, was the right one, it didn't work in my 25 pin rs232 port. The computer lab has 9 pin sockets, so that is fine. b) my code had a few bugs. Below is my completed working code, for archive purposes. Thanks for all your help.
module test(input CLOCK_50,
output LEDR,
output UART_TXD,
input UART_RXD,
input SW
wire serial_clk;
new_clock pll(.inclk0(CLOCK_50), .c0(serial_clock));
reg waiter = 12'b0000000000000; //counter to reduce clock rate
//reg waiter = 13'b0000000000000; //counter to reduce clock rate
reg state = 4'b0000; //current state. 0 = start bit, 1-8 = data bits, 9 = stop bit, other = ended
reg data = 1'b1; //start high = idle state
reg clk_new = 0; //changes the state of an led every time a bit is sent
reg origData = 48'h00_4F_4C_4C_45_48; //HELLO in ascii, little endian
reg currData;
reg started = 0;
assign LEDR = data; //led outputs current data bit
assign LEDR = SW; //led outputs status of a switch
assign LEDR = clk_new; //led shows when new bit is sent
assign UART_TXD = data; //assert the transmit wire to the data bit
always @(posedge serial_clock) //every clock tick
begin
//if (waiter == 27'b111111111111111111111111111) //1/2 times a second
if (waiter == 12'b1100_0011_0100) //9600 times a second (aprox)
begin
waiter <= 12'b000000000000; //reset counter
if (started == 0) //have we not started yet?
begin
if (SW) //start if switch 0 is high
begin
started <= 1;
currData <= origData; //set the current data register to be the original data register
end
end
else //we have started
begin
clk_new <= !clk_new; //change clock led
if (currData == 48'd0 && state == 4'h0) //end of transmit
begin
data <= 1'b1; //idle bit
if (!SW) //if switch 0 is low, then reset to not started
begin
started <= 1'b0;
end
end
else
begin
if (state == 4'h0) //start bit
begin
data <= 1'b0;
end
else if(state == 4'h9) //stop bit
begin
data <= 1'b1;
end
else if(state < 4'h9) //data bits
begin
data <= currData; //get first bit
currData <= currData >> 1; //right shift, so as first bit is the next bit to send
end
if (state == 4'h9) //update state
begin
state <= 4'h0;
end
else
begin
state <= state + 1'b1;
end
end //end data left to transmit
end //end started == 1
end //end if (waiter == ...)
else
begin
waiter <= waiter + 1'b1; //inc waiter
end
end //end always @...
endmodule
thats 9600 baud, 1 stop bit, no parity to send a 40 bit string
