18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
14 years agook then how bout the inputs....must i connect normal switch as inputs from the altera de-2 board
https://www.alteraforum.com/forum/attachment.php?attachmentid=5225 i have attached the picture of the pin assignment...im new in the rs232 section soe ur advise on wat input must i put is really valuable...is it the normal switch in altera de-2 which is from SW0 to SW17 ?? and for the Tx busy if its not connected in external wat output shall i assign since Tx will be assign externally to UART pin...pls Advise
